Transbrake on daily driver
I have a D1 style brake on my daily and with some tinkering it does really well. Most of the time it's undetectable. At the track I launch in D1 and then bump to D3 and let the computer handle all the upshifts. I would point most daily/street type users to a D1
But overall you will feel little difference with the brake for daily driving.
One concern rossler even states do not hold the brake more that 5 seconds at WOT temps in converter and pump can skyrocket (remember any energy not transfered to the wheel is HEAT). So lets say you stall to 4000 rpm with brake and you make 600 hp at 4000 rpm , You now have with brake applied a 600hp heat pump which can result in damage to the pump, bushing and seal. Also a hose to direct oil from overflow on top of trans just in case should be installed to direct oil away from exhaust out to frame rail just in case or to a catch can.
Also note with my VB setup the brake will function in D3 M2 and M1
The only other notable thing I have noticed over the years is heavy use of the brake does cause some searing of the rev input frictions and clutch plate erosion on the drum at splines but never seen a failure here just noted when doing restores on TRANSBRAKE UNITS. But unless you are a very heavy user nothing to be concerned with.
