Running the tranny cooler
.I now have a B&M race cooler, it is rated at 29k BTU. I don't know how the BTU rating compares w/the GVW rating but it is twice the size and thickness of my old cooler.
I bypassed the radiator this time and it hasn't gone over 160 on the street. It hit 180 at the track after 3 back to back passes and cooled down quickly after.
It does take a while to heat up on the street, about a half hour of driving to reach 150. Can the trans run too cool?
The B&M series coolers have a vicosity (thermal) bypass value. As the oil warms, the value opens and oil passes through this supplemental cooler. The warmer the oil, the more oil that goes through the cooler.
The higher the GVW rating on the tranny cooler, the larger the cooler is so that it'll accommodate more oil and generate more cooling. This cooled oil is then recirculated to the transmission.
I'm not sure whether the factory installed (stock) tranny cooler works under this principle (thermal bypass) or not but I do know that B&M does.
Hope this helps.
