4l60e no od or d
Old Sep 12, 2004 | 02:52 PM
bcuellar's Avatar
Default 3-4 shift problems 4l60e no od or d
I recently changed a & B solenoid and tranny was fine. then when driving it would not take off from od or d selection but if i placed in 1st or 2nd it would go then tried to place in d while driving it would work somewhat but would slip.did have tranny shaking in od or d when trying to go from a stop or a coasting speed.but not always. fluid changed and new filter. no codes.how many quarts of fluid is recommended? thanks.tranny rebuilt once in 2000. 1996 chevy s-10 4.3. wiring harness also changed in 2003.
Old Sep 12, 2004 | 04:36 PM
James B.'s Avatar
The sprag may be going out. I lost the sprag in a 60 once and had no forward in OD (4) or D (3). I could take off in first or second because the overrun clutches were holding.
Old Sep 13, 2004 | 07:09 PM
bcuellar's Avatar
well i know longer have any od or d had to get it home in 2nd, she ran pretty hot temp. it was bubbling, think im sol
Old Sep 13, 2004 | 08:28 PM
TeamTripp's Avatar
Definitly sounds like a sprag issue.
Old Sep 13, 2004 | 08:47 PM
bcuellar's Avatar
thats not all that bad to repair then is it? how much harm did i to tranny driving it home like that? how much is this to repair and how difficult . I do have alldatadiy.com
If i can find all info .thanks guys hope this is it.
Old Sep 13, 2004 | 09:02 PM
bcuellar's Avatar
No 3-4 Shift/Slipping or Rough 3-4 Shift
Governor weights binding.
Governor valve stuck.
Governor drive gear retaining pin missing or loose.
Governor drive gear damaged.
Governor support pin in case too long or short.
Oil pump assembly faces not flat.
Pump cover retainer and ball assembly omitted or damaged.
Accumulator valve, throttle valve, TV limit valve, 3-2 control valve, 1-2 shift valve train or 2-3 shift valve train stuck.
Manual valve link bent or damaged.
Valve body assembly spacer plates or gaskets incorrect, damaged or incorrectly installed.
Incorrect 2-4 servo assembly band apply pin.
Missing or damaged 2-4 servo seals.
Porosity in 2-4 servo pistons, cover and case.
Damaged 2-4 servo piston seal grooves.
Plugged or missing orifice cup plug in 2-4 servo assembly.
Third accumulator retainer and ball assembly leaking.
Porosity in 3-4 accumulator piston or bore.
3-4 accumulator piston seal or seal grooves damaged.
Plugged or missing orifice cup plug.
Restricted case oil passage.
Faulty input housing assembly. Refer to No 2-3 Shift or 2-3 Shift Slipping, Rough or Hunting . See: No 2-3 Shift or 2-3 Shift Slipping, Rough or Hunting
2-4 band assembly worn or incorrectly installed.
Old Sep 13, 2004 | 09:03 PM
bcuellar's Avatar
Internal converter damage.
Governor assembly drive gear retaining pin missing or loose.
Old Sep 13, 2004 | 09:08 PM
bcuellar's Avatar
what about this now ?
A/T - Upshift Flare/No 3rd or 4th/Launch Shudder
File In Section: 07 - Transmission/Transaxle
Bulletin No.: 00-07-30-026
Date: December 2000
TECHNICAL
Subject:
Automatic Transmission 1-2 and/or 2-3 Upshift Slip/Flare, No 3rd or 4th gear, Launch Shudder (Revise VCM Wiring)
Models:
1996 Chevrolet and GMC C/K, S/T, M/L, G1, G2, P3 Models
1996 Oldsmobile Bravada
with VCM and 4L60-E (M30) or 4L80-E (MT1) Automatic Transmission
This bulletin is being reissued to ensure that correct procedures are followed for this condition. Please discard Corporate Bulletin Number 66-71-03A (Section 7 - Automatic Transmission).
When performing a transmission replacement labor operation K7000 on these vehicles with a 4L60-E or 4L80-E, you must include front chassis wire repair labor operation N6112. Inspect the VCM to verify the latest part number revision (16244210).
Condition
Some owners may comment that the automatic transmission has either a slip or flare on the 1-2 and/or 2-3 upshift, or no 3rd or 4th gear, or launch shudder. Upon investigation, the technician may find a DTC P1870 stored in the VCM.
Cause
A poor internal ground between the two circuit boards of the VCM may cause the VCM to command erratic line pressure at the pressure control (PC) solenoid valve.
Correction
Using harness jumper wire and instruction kit, P/N 12167310, revise the wiring harness at the VCM connector. Corrections were made to the VCM beginning 2/14/96. The corrected VCMs are identified with service number 16244210 on the VCM identification label.
Procedure
The following is a summary of the instructions included with the service kit:
1. Remove the negative terminal from the battery.
2. Move the wire located at connector J3 (WHITE/GREY/CLEAR), pin 18 to connector J1 (BLUE), pin 23.
3. Install the jumper wire between connector J2 (RED), pin 26 and connector J3 (WHITE/GREY/CLEAR), pin 18.
4. Install the tag included in the kit around the. VCM wiring harness. This tag notes that the wiring harness has been modified.
5. Reconnect the negative battery terminal.
Road test to verify that the condition has been corrected. If any of the following conditions are noted, the transmission should be repaired or replaced using the most cost effective method. Canadian dealers should repair the transmission.
^ Transmission fluid oxidation or excessive sediment.
^ Transmission slip or flare after this service fix is performed.
^ DTC P1870 is stored on a 4L60-E (M30).
The following tools are available from Kent-Moore (1-800-345-2233) for use in removing and relocating the VCM wires:
^ J 41758 Terminal Tool; used to remove the wire from the VCM connector.
^ J 41759 Punch; used to punch a new hole through the connector seal.
Parts Information
Part Number Description Qty
12167310 Harness Jumper Wire Kit 1
Parts are currently available from GMSPO.
Warranty Information
Labor
Operation Description Labor Time
N6112 Wire Repair, Front Use Published
Chassis Labor
Operation Time
Important :Labor operation is coded to base vehicle coverage in the warranty system.
Copyright © 2004 ALLDATA LLC
Old Sep 13, 2004 | 09:48 PM
bcuellar's Avatar
Gear Train, 4L60E, which one is the spag part:
Old Sep 13, 2004 | 09:52 PM
bcuellar's Avatar
have all info on 4l60 e if any one needs it. im mean everything except how to tell whats wrong so many things cause same problems it seems.
Old Sep 13, 2004 | 10:26 PM
James B.'s Avatar
Not a very clear diagram, but part #42 appears to be in the right place and the right size.
This is a 4L80-E HD sprag, yours will look similar:
Old Sep 14, 2004 | 06:11 PM
bcuellar's Avatar
thanks james
Old Sep 15, 2004 | 09:56 PM
bcuellar's Avatar
now today mil went on and i got codes 753,758,1860,1864 and 1886. but tranny now has drive again no od cleared codes and thenj there was no drive again so i pulled the fuse and mil went back on and got same codes. so my ? would it be the sprag still.
or somthing else maybe. ie wiring harness
Old Sep 20, 2004 | 11:07 AM
bcuellar's Avatar
well I went with the 97 just got done with install but low and behold now I have nothing at all, old trany at least had 1,2,r
after topping off fluid ran truck for 20 mins still on front wheel ramps went to drive it down and test her out and nothing all gears, here is what im seeing wrong dissconnected top tranny cooling line from the rad and no fluid flowing, fluid is showing full in this position and dip stick would be up so if anything should read low then I called it the nite. so is it because im still on ramps or is pump shot or did I forget somthing I did check to see if I did dont see anything off hand, except hose on top center of trany is this vacume or overflow? this is a used tranny.
Old Sep 20, 2004 | 09:25 PM
James B.'s Avatar
...just got done with install but low and behold now I have nothing at all....
That's a bummer, I understand your frusteration.
Does it have a filter in it?
Old Sep 21, 2004 | 04:47 PM
bcuellar's Avatar
tranny is out of 97 jimmy, I took out tranny and it looks like i didnt get it seated all the way because off the way i did it.
pump and torq conv. was not seated looks like i busted up the pump. now can i take the pump out of old tranny and put it in the 97 and how . can i take pump out without getting hit with a tons of springs. now i know why it cost so much to rebuild and replace tranny. really isnt that easy to do in home garage. would have been if i known that you should place torq on tranny a fit it that way but thought it was very well lined up but wasn't and busted pump up.
would take it to a shop but everyone is behind 2 weeks so how do i get pump out do i need to tighten bands before doing anything or can i just go and take pump.
omne thing i cant see is how you would tighten torq to flywheel is there enough room sure doesn't look like it .
