OFFICIAL "I want a B&M or Hurst RATCHET SHIFTER for my '98 and above F-Body" Thread
http://www.bmracing.com/index.php?id...ubcat=1&pid=10
![](https://www.jegs.com/photos/13080683.jpg)
80683 - General Motors - TH 700-R4, 400, 350, 250, 200, 200-4R* 3 & 4 speed (* fits 4L60E & 4L80E with used with custom installation where an aftermarket controller is used to command the transmission.)
hmn..... that would be sexy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Moderator
hmn..... that would be sexy![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Moderator
Originally Posted by Bad30th
That pic is from the thread in your first post, post #12.
Bad30th
Bad30th
![](http://www.bmracing.com/media/products/items/6_full.jpg)
into a Trans Am console to get that look. I just thought it was a good concept.
Or this Universal "hammer" shifter:
![](http://www.bmracing.com/media/products/items/5_full.jpg)
Originally Posted by Black LS1 T/A
So... you're saying the bolt pattern allows the Quicksilver to bolt right in to our late-model F-Bodies? It just needs top-end modification?
"with used with custom installation where an aftermarket controller is used to command the transmission."
my best guess it will work you just have to customize the housing for it to fit into our consoles.
#33
Moderator
Originally Posted by kp
*shrug* Get a M6 console top and a B&M Hammer, hard to get any more stock looking then this. I say it took about 45 minutes to install and I had to make a plate to cover the giant hole in the floor from the M6.
Where did you get your M6 console? What did it run ya?
#34
Moderator
... I had to make a plate to cover the giant hole in the floor from the M6.
#35
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#37
Currently our shifters are too tall for use under the stock A4 console, you can use a manual console with a boot to hide the mechanism. The problem with our shifter mount is that the mount holes are staggered and will not bolt up directly to the OE shifter mount holes. I am trying to push to change this, but we are trying to get some other high priority projects out first. Keep the interest coming though, as I will show the interest to our marketing office.
#38
Wait... you installed into an existing M6 setup. Do you know that the mounting will be the same for an existing A4 setup?
Previous owner molded the upper console with bondo on the a4 console in the car I have now, turned out pretty nice also.. Its a B&M pro ratchet.
#39
Moderator
My question, though, kp, is how you bolt it to the floor. It doesn't mate to the existing pattern. Did you drill-to-fit sheet metal screws, drill and install bolts from bottom or top, have to make a custom bracket, etc, etc?
