trans will not shift,stays in drive
Old Feb 4, 2005 | 09:45 PM
teamspank's Avatar
Default trans will not shift,stays in drive
I have a 96 240sx with a 99 LS1 and auto trans.wired it in, engine runs great but will not shift,stays in drive.does the trans have a power wire?
Old Feb 4, 2005 | 10:47 PM
Full-Force's Avatar
more than just a power wire ..... sounds like your 3-2 and 2-1 downshift solenoids are not working
Old Feb 5, 2005 | 12:01 AM
sleeperstyle's Avatar
so it also cannot be manually shifted to any gears but D ?
Old Feb 6, 2005 | 08:25 AM
teamspank's Avatar
YES,you can change it manually.
Old Feb 7, 2005 | 01:25 AM
LS1FIRE's Avatar
OFF topic tho a ls1 240 swap sounds cool. And i never heard of it acomplished. do you have any pics of your setup? Thanks
Old Feb 7, 2005 | 03:46 AM
MNR-0's Avatar
When did it start occuring? Have you done a diff ratio swap recently? Has anyone reflashed your VCM?
Old Feb 7, 2005 | 08:36 PM
teamspank's Avatar
YES PICTS,www.streetracinggallery.com there is a couple of picts.under Nissan,imports.car is green/black.car runs great,just sometimes when in overdrive,it will drop back to drive and let off gas,like its in neutral.THANKS if someone can help.
Old Feb 7, 2005 | 08:52 PM
teamspank's Avatar
picts herehttp://www.streetracinggallery.com/cgi-bin/gallery/streetracinggallery.cgi?img=0&search=NISSAN&cat=Im port_Cars&bool=and&x=8&y=6
Old Feb 7, 2005 | 10:30 PM
LS1FIRE's Avatar
Do you any pictures of the under the hood? And under? What kind of rear are you using thanks
Old Feb 8, 2005 | 11:49 AM
teamspank's Avatar
IF YOU GO TO THE OTHER POST CHECK IT OUT,THERE IS PICTS OUT THE MOTOR.EMAIL ME FOR MORE PICTS JGARMON4@CAROLINA.RR.COM
Old Feb 8, 2005 | 12:30 PM
teamspank's Avatar
its all stock 99 LS1, stock trans 3000 tci stall.stock computer never flashed,sence in the car.
Old Feb 10, 2005 | 08:48 PM
teamspank's Avatar
need some help!car changes gears really fast.15 feet 1-2-3-4 all 4.why?all i did was put in a stall tci.
