How streetable are the 4000+ converters?
3000-3200 is super street friendly and you'll hardly notice anything different until you punch it.
3400-3600 is street friendly and the most popular stall size for stock motors and daily drivers. You'll feel a little looseness and it'll take a few weeks to get used to, but then it'll feel stock.
3800-4000 is streetable to some and too much for others. This is where people decide what they can and can not stand as far as stoplight to stoplight driving.
If you stay with stock gears then go with a 3500 stall. If you upgrade to 3.73's then a 3800 or 4000 stall with a 2.7 STR should feel pretty good if you don't mind a little looseness.
Hope this helps and good luck
Some might think it's a little much, but one trip to the track and I didn't mind it being loose at all.
Hey gator do you ever play on the interstates late at night????
I think that was you
Sorry I do not know much about TCs. When you say loose, are you refurring to shifts, or somthing else?
JA
When I say it's loose...basically how much pedal you need to get the car moving. Obviously when you floor it the RPM's will go way up. It's normal driving that people are worried about. The STR will afect how loose the converter is.....along with the gear ratio. The difference between the 2.73's and 3.73's was night and day for me.
Just trying to get all my stuff down so when I buy a tc I don't buy the wrong one or something that's gunna eat through tires like crazy. ( 3.23 gears )
