Old May 13, 2016, 12:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Transmission Guides
Print Wikipost
Change transmission fluid?
Old Mar 16, 2005 | 11:07 AM
98blackgold's Avatar
Question Change transmission fluid?
Should I change my transmission fluid? I have about 68,000 miles and am going to get a TCI SSF and a cooler installed pretty soon and wanted to know if it would be okay. The car has never been to the strip and is occasionally opened up. I've been reading either change the fluid regularly or don't do it all. What do you guys think?
Thanks!
Old Mar 17, 2005 | 01:55 PM
LS1s R US's Avatar
Might as well change it. If it still drives fine should be alright. Ya don't want to contaminate the new convertor ought to look into a transgo shiftkit it will help hold the power!
Old Mar 17, 2005 | 02:12 PM
GregWS6&z28's Avatar
it'd be a good idea. and if youd encounter any problems it'd be easier to inspect the fluid knowing it was new when the converter was new
Old Mar 17, 2005 | 02:32 PM
LS1LT1's Avatar
Thumbs up
You lose a lot of fluid in the converter swap anyway, may as well change it all during that time...that's what I did when I put my converter in, new filter, gasket and fluid.
Old Mar 17, 2005 | 04:39 PM
jlashley2001ss's Avatar
how often should u change ur tranny fluid after a stall converter?
Old Mar 17, 2005 | 10:14 PM
ULTIMATEORANGESS's Avatar
if your car sees regular track use it should be changed at least once a yr.
otherwise every 20-30k
Old Mar 17, 2005 | 10:34 PM
FelixIlka's Avatar
How hard is it to change the transmission fluid? I want to do a complete fluid overhaul when I get my TA as it's fluid that's been in there for 6 years ( even though it only has 18.7k on it ). Should I just pay the what like 75 bucks and have a shop do the changes or is it fairly easy?
I also want to do the fuel filter, coolant, and rear too.
Old Mar 17, 2005 | 10:48 PM
Cody Brooks's Avatar
80,000 miles or more on original fluid then do not change it especially if it smells burnt. if it smell burnt regardless of miles or doesn't shift right then do not change it. I had a guy want a tranny service done on a blazer with 88,000 miles and burnt tranny fluid I refused to do it for that reason and explained why it was then he learned that swapping tranny fluid doesn't fix a tranny thats slipping or not shifting correctly. I made the mistake of doing that one time and about a week later the tranny went out completely learned the hard way on that one.
as for difficulty to do. you have to drop the tranny pan, change filter install new gasket onto the pan and reinstall the pan then pour in 4 and half quarts. start engine put into reverse then neutral then drive,3rd,2nd,1st and back to park and repeat a few times to move the fluid through the tranny, then check level should need another 1/2 quart. then run it through the gears a few more times then check fluid level drive it a mile or 2 check level and it should be good to go.
