Idle Too High with ST3500
thanks
SES lite from high idle = your idle is now 200 rpms or higher than it was programmed for. Check for
-vacuum leak
-Do you have too big of a hole in your TB for the idle air hole?
-Try closing the blade on by using the idle set screw... this would help the most.
Loco, you need more air. Try raising the set screw on the TB you can go up. Or go one drill bit larger with the idle air hole.
You should see the hole in mine, I run a huge camshaft with 240 duration.
Tried the idle set screw
It's an MTI Ported TB... I was unaware if they drill out the idle hole any, I doubt it... I'm trading throttle bodies with a friend just to see if that could be it. This wasn't a problem before the converter went in... hmmm
[ December 07, 2001: Message edited by: monSSter1191 ]</p>
Only other problems I've had are:
Occasionally doesn't lock-up at all. I have to pull over and turn the car off and start it right back up and its fine.
SES light...shift solenoid stuck on. its thrown that code several times since install.
If you just have a ported TB and nothing done to the hole in the throttle blade, it shouldn't be the prob. IMO
GL
Rick
