Do I need a deep tranny pan?
Old Apr 7, 2005 | 05:39 PM
BoneSS's Avatar
Default Do I need a deep tranny pan?
Going w/ a 4200/2.35 str stall and have a 24k cooler. Do I need the pan also? Thanks!
Old Apr 7, 2005 | 07:29 PM
LS1LT1's Avatar
It's not mandatory but it really could help, the cooling benefits and extra fluid are good insurance to have with a bigger stall like that IMO.
Old Apr 8, 2005 | 11:36 AM
Ragtop 99's Avatar
Keep an eye on your temps if you FTRA, but it is probably not needed if you have a 160 T-stat and matching fan settings
Old Apr 8, 2005 | 02:39 PM
BoneSS's Avatar
I have none of those parts...
Old Apr 8, 2005 | 07:46 PM
JNorris's Avatar
Moderator
I do not think you really need one but I bought one of the GM truck pans (GM part # 24215535) with the drain plug. The drain plug is really handy and it holds about 1.5qts more fluid than the stock F-body pan.
John
Old Apr 8, 2005 | 08:26 PM
CamaroCain's Avatar
I did all the precautions possible for my tranny; cooler, deep pan, & trans temp gauge.
Old Apr 9, 2005 | 03:53 AM
BoneSS's Avatar
Thanks for the input! Something to consider. I will be down there anyway...
Old Apr 9, 2005 | 09:44 AM
4mula's Avatar
a larger pan is a good idea. ill be doing one soon myself
Old Apr 9, 2005 | 10:51 AM
Yank's Avatar
With that stall you need to replace the LOST fluid that happened with the use of a smaller converter.
The smaller converter uses about 2 Qt's less fluid and that is lost in your system that is one reason that there can be cooling problems in some setups!
always go for an increase in the system of no less than 1 Qt more that stock for a converter more than 2000 rpm over stock.
Good luck
Old Apr 9, 2005 | 10:56 AM
ULTIMATEORANGESS's Avatar
Good luck
thats good info.i never knew that.
Old Apr 9, 2005 | 10:57 AM
BoneSS's Avatar
Thanks--that is some great info. Looks like I need to change the tranny fluid while I am in there
Old Apr 12, 2005 | 03:12 PM
BoneSS's Avatar
Is it a must though? Concerned about ground clearance.
Old Apr 21, 2005 | 04:42 AM
BoneSS's Avatar
What pans do you all have?
Old Apr 21, 2005 | 01:10 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Smile
I have a Y3000 2.0 STR in my 01 Z28. I have a B&M 24K cooler and a B&M 3Qt. deeper aluminum pan. My trans temps on the freeway (hot day or cold) never rise above 140F. In town my temps run a little higher between 150 & 175 depending on the outside temperature. I live in a very warm climate.
If your vehicle is NOT lowered, go for the B&M 3Qt. aluminum pan.
SteveC
Old Apr 21, 2005 | 05:17 PM
BoneSS's Avatar
Old Apr 21, 2005 | 09:27 PM
BoneSS's Avatar
How about the TCI pan that Speed Inc sales? 2 qts extra...
Old Apr 21, 2005 | 09:34 PM
the more capacity the better.
Old Apr 22, 2005 | 07:09 AM
SteveC's Avatar
Any quality deeper ALUMINUM pan is the way to go, they are more expensive than the steel counterparts, however they disapate heat better.
SteveC
Old Apr 22, 2005 | 03:11 PM
BoneSS's Avatar
I think I will just get the B&M.
Old Apr 23, 2005 | 07:49 AM
SteveC's Avatar
Smile
Good choice, providing your vehicle IS NOT LOWERED. This pan hangs down low, on my stock height vehicle I have 5" clearance from the ground to the bottom of the pan.
SteveC
