They said it couldnt be done Megashifter
Old May 1, 2005 | 08:11 AM
Gold Member's Avatar
Default They said it couldnt be done Megashifter
Here is my 98 Sport Gold TA with my megashifter from my 87 GTA. I was able to save this part before the car went to the wrecker... Some minor mod required, nothing crazy..
Old May 1, 2005 | 11:48 AM
monsterls1's Avatar
what did you have to do to get that in?
Old May 1, 2005 | 01:10 PM
not much really, just remove the old shifter, then line up the new one making sure its "a little to the right", then put some bolts in and run a tranny cable... Some odds and ends electrically but i can tell you how to do that...
Old May 1, 2005 | 03:04 PM
BubaGumpShrimp's Avatar
dude please tell, lots of people looking for this kind of thing but no one knows. Is it just the regular meaga shifter for the 700r4, any part numbers for that shifter you have...
Old May 1, 2005 | 04:39 PM
mimic42100's Avatar
that looks really nice.
/me chats write up!
i'd like to have one of those in my ride =)
Old May 1, 2005 | 07:30 PM
This is the B&M Megashifter it is the 82-92 Console Shifter..
It is fairly easy to install.. I had to use the cable that came with the shifter, because its adjustable.. but i love the idea of the Ratchet action... cant miss shift or accidentally throw it in park.
Old May 1, 2005 | 08:24 PM
monsterls1's Avatar
how high does that stick up out of the console, i'd like to cut a couple of inches off but i don't have a welder to weld the pieces back together. also is that a 4l60e because i heard you need some kind of electronic controler since the 4l60e is electronically cotrolled?
Old May 2, 2005 | 06:37 AM
Its really only about two and half to three inches above the console, you really cant lower it any because it will push down on the console when ratcheting....
the electronics are controlled at the tranny not the shifter, still shifts like its supposed to in drive....
Old May 2, 2005 | 06:40 AM
so did everything basically bolt up the same or did you have to drill new holes and move stuff around
Old May 2, 2005 | 10:06 AM
I did have to drill new holes, but i didnt need to go under the car to due this, i only had to go under the car to put the new cable on and adjust it.
Old May 2, 2005 | 11:54 AM
ok, just wondering why then that b+m hasen't mad this for our year cars since its basically the same as the older megashifter.
Old May 2, 2005 | 05:48 PM
God Forgives I Dont's Avatar
It might controlled at the Tranny on your 98 but I've had mine console apart on my 99 T/A before to fix some rattles and to look at replacing it and found that on the side of mine there is a black switch box that tells the pcm what gear you have the shiter in at any given time. Thats the tricky part but I have seen several sucesfull setups before I just haven't liked the way the others have done the boot or gear selector setup, until now!
Very clean looking install! definatly the best looking install I've seen yet and I would love to see more pics and a write up on your install.
Old May 4, 2005 | 09:23 AM
CWallen's Avatar
A write-up on how to install this shifter would be awesome. Specifically, what are the electrical modifications you talked about that are needed to make this work? The basic install should be pretty straight forward. I have been wanting a ratchet shifter in my 01 WS6 that would still apear semi-stock for a long time and if the Megashifter can be put into my car that would be great.
Old May 4, 2005 | 08:46 PM
TransLS1's Avatar
that looks pimp man nice install. definetly do a write up, if you could pm me what you had to fab up cuz my friend has one and i wanna buy it from him but didnt really know where to start with it.--Andrew
Old May 5, 2005 | 09:53 PM
Bad30th's Avatar
Awesome !! I've been wanting to do that forever. Can you please PM me the details to install on my '99 ?
Thanks !!
Bad30th
Old May 7, 2005 | 03:51 PM
00firebird's Avatar
who shifts an auto?
Old May 7, 2005 | 03:54 PM
anyone with a shift kit and programming ***** an auto. If you dont have either than its somewhat pointless since the computer wont let you shift where you want to
Old May 7, 2005 | 04:06 PM
00Z28 Camaro's Avatar
More pics !
Old May 20, 2005 | 12:20 AM
BowmansRedAlert's Avatar
Without a doubt! Mad propps to you for achieving this! Please list and show how you did this. Just think, you did what B&M has not got off there a** and done for us! You rock!
Old May 20, 2005 | 12:21 AM
Originally Posted by 00firebird
who shifts an auto?
I would, especially if I had a ratchet shifter!
