Problems with new Torque Converter
Old Dec 28, 2001 | 02:07 AM
DravenMyers's Avatar
Default Problems with new Torque Converter
My Yank TP4400 was installed yesterday. The guy didn't install the cooler becuase there wasn't enough time (long story). So that same day, as I was driving it home, I decided to punch it off the line, and I felt just a LITTLE difference <img src="gr_sad.gif" border="0"> I was expecting it to pull a lot harder than that <img src="images/icons/confused.gif" border="0"> So, I tried it a few more times and to my disappointment, I had the same result. Well, today I took it out for another spin. I drove to a deserted area, which took me awhile to get there. On the third run was when my problem started. I floored it and my car took off VERY SLOWLY <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" /> I tried it again with the same result. Is it because I had no cooler? Did my tranny get too hot <img src="images/icons/confused.gif" border="0"> I need help guys! My SES lights also come on and my car still lurches forward a bit when I take my foot off the brake...I thought it's supposed to stay still? I really need help fellas, thanks in advance.
Old Dec 28, 2001 | 09:06 AM
Ragtop 99's Avatar
Default Re: Problems with new Torque Converter
If the tranny overheats you'll have problems.
Make sure your coolant is right, that the tranny cooler lines aren't pinched and find out what the SES light is. Anybody near you with ATAP
I wouldn't beat on it untill you figure out the problem. You should have no problem breaking the tires loose when you launch hard with that converter.
Old Dec 28, 2001 | 09:19 AM
Patrick G's Avatar
LS1 Tech Administrator
Are you running a ported MAF? Did the installer disconnect the battery upon install? If so, then your pcm memory was wiped out and it will take about 200 miles to relearn. It takes a while for a tranny to get wiped out, even without a cooler. You may have gotten an SES light because your car went too lean before it had time for the pcm to "re-learn". Drive it for a while. Put some easy miles on it. Punch it 200 miles later (hopefully with a cooler on it) and report back.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 28, 2001 | 01:59 PM
WILWAXU's Avatar
Have you checked the tranny fluid?
Old Dec 28, 2001 | 04:28 PM
EvilLS1's Avatar
Yep, if you haven't already done so, double check your tranny fluid, and then check it again! I had to add fluid 3 seperate times before it was at the right level.
Old Dec 28, 2001 | 04:59 PM
mmiller's Avatar
Texas Director
I agree with everyone else. Check, double check, and triple check the tranny fluid. Go drive the car (normally, not hard) between each fluid check. Your car probably went into limp home mode. Shut the key off for about a minute. Start up the car and you should be OK, except for the SES light.
You need either an AutoTap or need to pull the PCM Bat & PCM Ign fuses to clear the SES light. Also, try keeping the tranny in "D" instead of "OD" when driving under 50 MPH.
Old Dec 29, 2001 | 02:50 AM
AlonzoVersion 1.0's Avatar
[quote]Originally posted by DravenMyers:
<strong>My Yank TP4400 was installed yesterday. The guy didn't install the cooler becuase there wasn't enough time (long story). So that same day, as I was driving it home, I decided to punch it off the line, and I felt just a LITTLE difference <img src="gr_sad.gif" border="0"> I was expecting it to pull a lot harder than that <img src="images/icons/confused.gif" border="0"> So, I tried it a few more times and to my disappointment, I had the same result. Well, today I took it out for another spin. I drove to a deserted area, which took me awhile to get there. On the third run was when my problem started. I floored it and my car took off VERY SLOWLY <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" /> I tried it again with the same result. Is it because I had no cooler? Did my tranny get too hot <img src="images/icons/confused.gif" border="0"> I need help guys! My SES lights also come on and my car still lurches forward a bit when I take my foot off the brake...I thought it's supposed to stay still? I really need help fellas, thanks in advance.</strong><hr></blockquote>Dont know if this helps you but when I had my old vig 2500 I couldnt launch over 1500 or the computer would read it as a slip I am guessing and so I got my computer reprogrammed.Not to say you will need to but it does take time for the computer to adjust to anything new on the car.Give it time bro.
Old Dec 29, 2001 | 02:29 PM
Thanks for the replies guys. Ragtop, no one around me has Atap. Patrick G, i'm running the Granatelli MAF and i'm pretty sure the installer did not disconnect the battery. I haven't seen my car since that day so, I haven't had time to check my tranny fluid. Hopefully tonight i'll be able to. Thanks again <img src="gr_stretch.gif" border="0">
