1 st gear boggs when you power brake ?
Old 06-20-2005 | 09:05 PM
CANXLR8's Avatar
Default 1 st gear boggs when you power brake ?
I have a Yank 3200 and my trans was done by atd It works fine except for a couple things.
1. When In 1 st gear manually and you hold the brake and stomp it , It revs just a little and then seams to go into a limp mode . Has any one heard of this happening before ?
2. When I am crusing along and tap the brake the rpms fall way down and then the trans jurks a little then returns to normal.
Any help would be great thanks. Nyle
Old 06-20-2005 | 11:26 PM
James B.'s Avatar
That's called "abuse mode." The PCM knows what you are doing and is taking timing out.
Old 06-24-2005 | 09:34 AM
Mitzelj's Avatar
No wonder you could keep up with that blue vette, TC explains the low mph. Jeff
Old 06-25-2005 | 06:41 PM
ChevyGoldfinger's Avatar
Know anyone with LS1 Edit or HP Tuners? You can have the evil GM "torque management" tuned out, and a few other things at the same time. (adjust shift points, check your air fuel ratio, etc. etc.) Good luck!!
Old 06-26-2005 | 07:29 AM
Ragtop 99's Avatar
On the highway the converter locks up. When you tap the brakes, it unlocks.
Have you double checked your fluid level, changed the filter? A brake torque launch should not put the car into abuse mode.
Old 06-26-2005 | 08:52 AM
CANXLR8's Avatar
I just had the car tuned at Livernois , And it still does it. I'm going back in 3 weeks for a turbo install , So maybe they can fix it then. I hope after the turbo install I won't have to power brake it.
Blue vette ! I said I had a converter . It's my sons Z that don't. Hi Jeff.
Thanks.
Old 06-27-2005 | 06:20 PM
blewbyu's Avatar
Default Bog
Thanks.
Had the same thing happen to me with my Yank . I sent it out to be restalled . Make sure you tell them if it is N/A or turbo .
Old 06-28-2005 | 01:26 PM
Mitzelj's Avatar
Thanks.
Guess, I missed that! Good seeing all you guys! Good luck with the turbo. Regards, Jeff
