TH 400 Length ??
Old 09-06-2005, 01:34 PM
SgtB's Avatar
Default TH 400 Length ??
my trans is 31" from bellhousing to tailshaft....does anyone know what size tailshaft that is????
Old 09-06-2005, 01:54 PM
BADSZ28's Avatar
Short shaft or long shaft? LOL!
Old 09-07-2005, 07:45 AM
SgtB's Avatar
nobody knows??
Old 09-07-2005, 08:56 AM
12secSS's Avatar
Long tailshaft!
TH400 Long Tailshaft Length = 30-5/8"
TH400 Short Tailshaft Length = 28-1/4"
Old 09-07-2005, 09:26 AM
SgtB's Avatar
Thank you. So does this mean I can use my stock driveshaft with a different yoke?
Old 09-07-2005, 05:45 PM
SgtB's Avatar
ok anyone know the length of the driveshaft.
Comparison #'s from a stock 4L60E driveshaft to what is needed would be best.
Old 09-07-2005, 07:27 PM
jxaxsxoxn's Avatar
Originally Posted by Flame Throwing SS
Long tailshaft!
Thats funny....the short tailshaft housing is 4 inches and the medium is 9 3/4 inches. Thats a 5 3/4 inch difference.
The cases are all the same length.
You better take a more accurate measurment. The overall length of the short one (4" tailhousing) is 28 3/8 inches.
The medium one (9 3/4" tail) is over 33 inches.
Old 09-27-2005, 03:53 PM
Jim Adams's Avatar
I didnt want to be the one to say anything happy you did lol the short shafts are all the same and the long shaft are too,,the difference is the long shafts where used in the olds ninety eights the Catalinas and some truck applications,( but most trucks used the 275) most of the big 4 door cruise boats and the short shafts where used in all the camaros, chevelles, novas ,GTO,s ect.
Old 09-27-2005, 04:31 PM
jxaxsxoxn's Avatar
Not 100% true. There were 375's in the 70's, they were marked with 375 cast into the tail housing and they had a th350 size yoke. And fewer clutches.
In the late 80's they brought that configuration back only they were no longer called 375's, they were regular th400's with a long tailhousing and th350 size yoke.
I've seen 3L80HD's with the small yoke, long tailhousing.
Old 09-27-2005, 04:39 PM
Yank's Avatar
Product Update
Yank has also just introduced a special kit to allow the use of Your stock or replacement 4L60-E drive shaft!
You will not have to replace your carbon fiber or special drive shaft when this kit is orderd or installed with one on our TH400 units
Features of this exclusive Yank item are:
Custom output shaft in the 4L60-E spline
Reworked extention housing so the TH400 is overall the same as the 4L60-E
also included special high RPM seal, and rear bushing with increased oiling
https://ls1tech.com/forums/showthrea...0&page=1&pp=20
Old 09-28-2005, 06:54 AM
SgtB's Avatar
Damn,
Wish you would have told me earlier. I just got done spending $980 having my tranny rebuilt.
Old 09-28-2005, 08:04 AM
BADSZ28's Avatar
Wow, a nut hair below your cut-off.
