View Poll Results: state what year your car is or if yours is still good
cracked 1998 car
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
7
3.43%
cracked 1999 car
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
6
2.94%
cracked 2000 car
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
2
0.98%
cracked 2001 car
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
37
18.14%
cracked 2002 car
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
29
14.22%
still going strong
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
123
60.29%
Voters: 204. You may not vote on this poll
Who cracked their flywheel.. should i upgrade..
#66
My vote goes for the TCI flexplate. i have one with a yank converter - no issues thus far.
speedinc stocks them and ships out quick!
www.ls1speed.com if you're interested.
#71
i have a 2002 where the flexplate let go and 1/4 of the flexplate went through the bottom of the bell housing, removing a large chunk of cast aluminum. it broke off 2 of the bolts holding the stall on as well as breaking off one of the ears of the oil pan and cracking the other and breaking off 3 of the rear cover bolts.
my friends 99 just did the same thing to his motor
these flexplates are crap. if you are anything more than a header car you need them. his car just had nitrous and it killed the flexplate. the 2002 i have was stock and it broke its flexplate.. i just ordered the TCI flexplate. its a great piece, just remove the powdercoating with a razor blade. im using it on my 4000 stall/cammed car and i have not had problems with it so far.
#75
LS1Tech Sponsor
Its not absolutley nesesary but a good idea What can happen with both paint and any coating is the coating breaks down and since it acts as a space between the converter and flex plate once this happens and otherwise tight bolt can suddenly become loose
__________________
#78
They said that loose bolts on the bellhousing would not lot it rock up and down and that you said that only to cover your ***. So long story short I bought a new one and am installing it myself.
#79
LS1Tech Sponsor
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
#80
Man I hope to hell the only thing to get screwed up tranny wise was the flexplate. I also have to buy a new starter because one of the torque converter bolts sheered off the front part of it. But I have a buddy that is a manager at O'riles and is gonna get me one at employee cost.
