I tested my shift extension on the Yank ST3800
Re: I tested my shift extension on the Yank ST3800
Those numbers are about right Terry, but the funny thing is...even if you shifted your car at 6200, the rpms would still only drop to about 5100 rpms with the ST3800. Thanks for the feedback. Keep it coming.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
So would it be fairly accurate to say that with a ST 3200 the shift extension should be 4500-4600, as that is what I'm hoping for with my setup.
Mike <img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
That's about the right rpm range for the ST 3200 Mike.
Patrick
Patrick
__________________
I held the following shifts (measured 2-3 upshift)
TT 2800, some bolt-ons, no headers: 4000-4200
ST-3500, some bolt-ons, no headers: 4500-4600
ST-3500, full Bolt-ons & headers: 4700-4800
YTP 4000 with 218 cam: 5200
YTP 4000 with 218 cam & untuned blower: 5600
YTP 4000 with TR224 & heads, bad cylinder: 5500
All 3 converter upgrades had a definite SOTP improvement from a roll.
Wow if the TP4000 gives a 5500rpm shift extension with heads/cam, I wonder what the TP4400 will do? What were your flash speeds with the various mods?
Thanks
Thanks
With around 400rwhp, it comes out of the hole ~3900rpm, and with 6800-6900rpm shifts my rpms drop down to the 5100rpm range. What numbers are you guys seeing with other converters?
I assume the TP4400 will show ~4500rpm launch, ~5500rpm shift extension with 6900rpm shifts. Sound right?
Terry I should be able to tell you next week. Is Carlsbad going to be open for test/tune on saturday the 2nd? I hope so.
[ February 23, 2002: Message edited by: Jantzer98SS ]</p>
Terry:
I hold pretty high rpms on the 4000 because it is a lower stall version of the 4400. As a result, my STR is slightly lower then a 4400 and the efficency of mine is a bit higher than a 4400. The 4400 is only good for another 100 -200 rpms of shift extension. The 4400 will have a bigger hit off the line and a little more midrange gain. The 4400 doesn't feel much looser than the 4000.
Your 3800 is a higher stall version of the ST 3500 and has a bit higher STR than a 3500 and is slighly less efficent, so you gain some shift extension over the 3500, but not a lot. It is not a linear extrapolation. By example, the ST 4000's shift extension is only 100 - 200 rpms higher than the 3500, but the extra stall produces a BIG bottom end and lower midrange increase.
I don't have reliable measures of what I flash to. I gave up trying to measure it on the street because of traction and at the track I'm focused on other things.
I'm kinda worried about ordering a new one, because I don't want yank to mess it up trying to compensate for my mods. If I tell them I have 400rwhp/425rwtq and want an off the line stall of 4600rpm and shift extension of 5600rpm, will I get what I want?
Terry:
A YTP 4400 will pretty much hit that target. Going smaller isn't probably worth the investment. UT4600 would probably work but it also seems that the 4600 & 4800 work best with cams biased for high end power and 6800 and higher shift points. If you had a Tbrake, the 4600 might be more appealing.
