What do I need to swap to TH400?
Thanks
BMR Xmember with TA Relocation $220
Shifter, ratchet type w/ cable $180
ATI or TCI Flexplate $180
TC, take your pick.............$200-$1200
Speedo adapter, I had Carl Rossler send me a 9" tailshaft with the correct bosses welded in for the TH350 conversion $200 and reluctor wheel since I didnt pull it off the 4L60E $20.
Transmission, again its up to your goal/budget $700-$3500
Trans Cooler, ditto $80-$300+
Only bummer about swapping for me was losing the exhaust hanger mounted off the tailshaft...but I am sure I will get over that once the new exhaust is hung
https://ls1tech.com/forums/automatic-transmission/197642-what-would-you-like-see-addressed-th400-faq.html
