How big should i go?
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
And I say, don't upgrade the trans until you have to.
If you do plan on installing a race built transmission, don't listen to anyone who says "don't upgrade until you have to", or "don't fix it if it isn't broken".
Well, most transmission builders require an exchange (sometimes with core charge) and I don't think they would be happy with you sending them a broken transmission.
I would never touch TM on a stock trans, reason being I would rather not bust it up. Others may say otherwise but that's my opinion.
I am doing transmission/converter/flexplate/mount/cooler all at once to keep things simplified with only ONE go of labor and no more. But that's just the way I like to do things.
i had the TM deleted back when i was still running the stock convertor, had no problems then, and have no problems now
the way i looked at it was, the LT1 F-bodies didnt have TM and they had the same transmission with no problems, i didnt think i "really" needed it
keep the thread going.Nelson
You will get mixed reviews in the whole shift-kit thing, but I did plenty of reading and research on them and I think if they are installed and setup properly the will help the life of the trans. Give Dana at pro built a call (search) and he will give you all the info/advice you can take in
As far a the TM issue goes i'm not going to completly eliminate mine but take a majorty out. Jimmyblue is the man fot that info.
but i got a trans with the stall at the same time
i have yet to have any trans problems (noises, grinding, slipping, ect...) on either trans
i was told to flush the trans fuild regualarly as in once a year or every 15K miles, its been proven to keep the trans alive longer
