is 4400 too much?
Old Feb 16, 2006 | 10:42 PM
1998TA__1991RS's Avatar
Default is 4400 too much?
is a 4000-4400 stall with a trex too big?? with a 4l65e?
Old Feb 16, 2006 | 11:12 PM
Smokinstorm's Avatar
Old Drag Racer
Since I'm running a PT4000 with a stock motor with just a few bolt-ons with success, I'd say a PT4400 would be great with a T-Rex. It's just going to be loose for driving around town but with a T-Rex you don't really care about that now do you? If you're thinking about spraying it either now or down the road, a 4400 is going to be too loose for you.
Old Feb 16, 2006 | 11:30 PM
SUX2BU's Avatar
Ide say a 4400 is the minimum for a T rex.
Old Feb 17, 2006 | 12:00 PM
s346k's Avatar
+1..
if you're looking to get the most out of a t-rex, get AT LEAST a 4400 stall.
Old Feb 17, 2006 | 05:45 PM
FACE's Avatar
4.10's out back will keep it from feeling too loose.
Old Feb 17, 2006 | 07:27 PM
its got a 3.73 in it what about a 4200?
Old Feb 17, 2006 | 07:37 PM
SUX2BU's Avatar
once you get above 4,000 stall they all drive the same. i bet if you just drove my 5100 stall around you would think it was a 4,000 or so. untill you floor it
Old Feb 19, 2006 | 07:39 PM
is that big of a stall really nesscessary though? im probably going with about a 4400-4500
Old Feb 19, 2006 | 11:54 PM
SUX2BU's Avatar
Ask these guys, the three fastest auto cam only guys
01-z------------10.295@128.48(1.38 ), 01 z, A3, ATI 5500 , 4.57, G5X4, -110,2880, 4/05
Magnus -------- 10.295@128.48(1.36 ), 97brd, A3,ATI 5500 ,4.10,G5X4, 200, 2820, 4/05
Dragaholic------10.34@127.46 (1.36 ), 00 SS, TH350, 5500 , 4.56, TReX, -700, 2850, 11/05
Old Feb 20, 2006 | 12:05 PM
FACE's Avatar
I went with a 4400 last time and wish I went bigger.
Old Feb 20, 2006 | 10:21 PM
how would you run through the 1/4 mile with a 3 speed with 5500 stall and 4.56 gears? what size tires are they running?
Old Feb 20, 2006 | 10:25 PM
keep in mind my car is a 4l60e
Old Feb 21, 2006 | 09:38 AM
chrs1313's Avatar
Sounds like you have your mind allready made up, SUX is giving u the best advice for max performance...so why even ask the question?
Old Feb 21, 2006 | 05:43 PM
SUX2BU's Avatar
I think they were running a 29.5" tire and if i remember correctly one guy's was a W tire.
Old Feb 21, 2006 | 09:12 PM
also how will a 5k+ stall feel with a 3.73 gear?
Old Feb 21, 2006 | 11:00 PM
SUX2BU's Avatar
Just fine. it really isn't as bad as people think. i bet just driving around town you wouldn't be able to tell the difference from a 4,000 stall to a 5k+ stall untill you stomp on it.
Old Feb 22, 2006 | 04:44 AM
Honda Hunter's Avatar
So what would be the downside to having a stall that big on a DD car?
Old Feb 22, 2006 | 08:38 AM
BAIN's Avatar
Gas mileage in town. In town the speed limit is 35-40 mph here. My converter doesn't lock up until 50 mph so I get about 10 mpg with my 4.30's and T-Rex cam. Out on the highway when the converter locks I get 20-21 mpg.
Old Feb 22, 2006 | 12:17 PM
SUX2BU's Avatar
Yeah i don't do much in town driving. i do about 95% highway and get about 20 mpg with NO overdrive on the highway. 4.10 gears/th350/31" street tires.
Old Feb 22, 2006 | 02:42 PM
BAIN's Avatar
You probably turn about the same rpm as I do on the hwy with those 31's and 4.10's.
I have OD, 4.30's, and 28's
