going from 2:73 to 3:73...worth it?
I think anything above 3.42's for the A4 is for serious speed guys.
I think 3.73's would be ok, but stall is def needed.
Not as true for 3.42.
I would however, recommend 3.42's for an Auto because you get a whole new animal, and you dont lose hardly any MPG.
3.42's and a nice stall should equal a .4-.8 tenths difference, and that is a damn good improvement.
somebody help me...
please read first...
you're really making an *** out of yourself, chocotaco. for the sake of argument, let's say a gear swap is STUPID and only something a bonified dumbass would do...with that said - last time i checked, it is within the rights of those who choose to do so. get off your high horse with the gear swap issue. put down the shovel and agree to disagree, insulting people (like me) doesn't get you anywhere, nor does it prove your opinions in any way, shape, or form.
And if you're car is an all out race car and you don't care about everyday drivability, I don't see why you wouldn't want them there either since they WILL improve your ET. I know someone who gained 7 mph in an LT1 vette from going to 2.59s to 3.73s
i find it so funny that some of the people in here yell at people after hearing noises due to aftermarket parts that "you're putting racecar parts on a street car, get over it", then complain over the looseness of a stall. it's a paradox i tell you.
my argument is the gears have more downsides. if you wanna lose major mpg, increase engine wear and cut your rear's life all because you're uncomfortable with a stall and need that extra tenth in the quarter, i think your priorities aren't in order. there are better things that can be had with the money.
gears + install kit + install run around $500-$600. i'll take the low end of $500 just to be a good sport. going from 2.73's to 3.73's should cut on average 3mpg from your car. no one should argue this, it's a good estimate. now, let's assume before the gear swap, you'll see 21mpg and let's assume you drive your car is a daily driver and you drive 250 miles a week. let's also assume premium gas is $3.30 a gallon, which by now may be the low average
[(250 miles)/(21mpg)] = 11.9 gallons of gas used each week
11.9 gallons of gas @ $3.30 a gallon = $39.28 a week to drive
$39.28 x 52 weeks in a year =~$2043
okay, it costs about $2043 a year to drive your car. now, let's assume you'll keep this car for 3 years.
$2043 x 3 = $6129
over 3 years, it costs you $6219 dollars to drive your f-body with 2.73's. now let's apply the same logic with 3.73's @ a rate of 18mpg.
[(250 mles)/(18mpg)] = 13.9 gallons of gas used each week
13.9 gallons of gas @ $3.30 a gallon = $45.84 a week to drive
$45.84 x 52 weeks in a year =~$2384
okay, it costs $2384 a year to drive your car. now, let's again assume you'll keep this car for 3 years.
$2384 x 3 = $7152
it cost you an extra $1023 to daily drive your f-body because of those 3.73's, and again, this is assuming you see absolutely $0 in adverse effects from engine wear and a broken rear. remember, 3.73's amplify the chances of both dramatically which could add thousands more to your bills.
okay. so add the $500 for gears, install kit and installation to the $1023. you get $1523 for the final cost of your 3.73's over the course of a meager 3 years (i will tell you, i plan to drive my f-body for a lot more than 3 years. i'm sure most of you would too
)okay, you spent $1523 to pick up 1-2 tenths in the quarter mile. now, what other mods can we get for $1523? hmm...you could get a t-rex cam and some forged internals, installed!
who here, on this site, would be happy with a 1-2 tenths gain in the quarter mile after a trex cam? if you honestly think 1-2 tenths are a great pickup after a trex cam, by all means, do the gear swap since you have no concept of good money spent. i'm done with this argument. it's total BS. anyone with any concept of wise spending and dollar per horsepower can see this.
Also, you need to consider the setup as a whole. After doing a cam and stall, you usually want to bump the gear ratio a bit. You need not consider each mod on its own, but the setup as a whole.
Also, how the hell do you get 20+ around town???? I get 14 best in city.
and for the record, i have the SLP package, so if it was on the corvette, it would theoretically be rated at 375hp since it was some like a 25hp package.
and FWIW, i have a 2001 bird w/LS6 intake, they were rated higher than 310 weren't they (even though the rating for the vette was still 350)?
i've never seen less than 21mpg in my car either. it's not detriot-style city driving. the lights are separated by .5 - 1 mile, not 100 feet. still stop-and-go for 8 miles straight.
my whole reasoning this whole time has been: if you're going to hurt your mileage, for the same damn price, why settle for 1-2 tenths off your quarter when you can get over half a second or more? i guess no one has figured this out yet as i have put it in nearly every post
err, didn't i say i was done with this argument?
Sorry, you are wrong. 98-2000 Fbodies were rated at 305hp factory (except SS and WS6 at 325). 2001-2002 added the LS6 intake, bumping it to 310. Do your research. I've had my car for 5 years. You've had yours for 2 months. Get your facts straight. The Vette motor is the same, but i think has a different cam profile, it also has a completely different exhaust system, giving it that 350 hp.
GM never offered any SLP package on Corvettes, because the Vettes don't need it since they flow very well stock. So your arbitrary logic of 25 more hp on a vette is just dumb.
EVERY 01' and up LS1 engine has the LS6 intake manifold. INCLUDING THE CORVETTE. Originally, the LS1 in the Vette was rated at 345 hp. Which i believe was upped to 350 with the intake change, but done in 2000.
As for the mileage, i still think its amazing you get that high with that kind of driving. Where did Detroit come into this? Weird how yours is so much higher.
You know, i understand you argument about the gears, you have some good points. But constantly repeating those points over and over is not helping you and you are coming off like a jackass. You made you points, people dissagree, now move on. With the hp reasoning you stated above, maybe you are wrong on other things as well.
i never said the vettes offered an SLP package. they don't flow much different at all over the LS1. the LS1 f-body dynoed the same as the vette also. ever see this?
yea, same motor. the camaro actually dynoed significantly higher than the vette due to the independent rear. get your facts straight, man. i mean god, it's even a sticky!
https://ls1tech.com/forums/showthread.php?t=458711
the f-body was dumbed down so the vette would LOOK more powerful. it's the same damn engine, same damn profile, same damn power. i think you're confused with the LS6 motor offered in the ZO6. the base corvette had the same LS1 as the f-body right down to the intake manifold (which was later switched in 2001 to the LS6 design).
fwiw, i'm trying to move on, but sometimes it's difficult as people keep putting words in my mouth and that drives me crazy.
i never said the vettes offered an SLP package. they don't flow much different at all over the f-body. the LS1 f-body dynoed nearly the same as the vette also. ever see this?
yea, same motor. the firebird actually dynoed significantly higher than the vette due to the independent rear. get your facts straight, man. i mean goodness, it's even a sticky!
man, school is in session and all of you are failing miserably.
