going from 2:73 to 3:73...worth it?
Also, you point out the power diff is "significant" between the f-body and vetter rw #s. I wouldn't call a 7 rwhp difference "significant" on a 350 hp motor.
2%. You claim it dynoed lower because of independed rear? It makes a diff at the dragstrip, but prove to me that independent rears dyno lower.Oh yeah, you posted twice. Mop it up.
the main diffrences between the F body and Y body LS1s are the exhaust manifolds, the no egr on the 97-00 Y bodies and then the accessory mounting.
oh, one last thing, dont get SLP headers, they are crap in tubluar form. get coated pacesetters.
Adding a heads/cam package---even with a "mild" cam (say a 224/228 grind)---will absolutely hurt your gas mileage more than a moderate gear swap will....period. Adding heads/cam significantly increases your motor's ability to move air in and out of the combustion chamber. That extra air requires extra fuel....at every single rpm, all day, every day-- not just "when you get on it". If the cam you pick has any significant overlap, you're even wasting quite a bit of fuel at idle.
In fact, after a head/cam swap, you'll probably have to stay up around 3k rpm or higher to move at the same rate as 2500rpm moved you when stock, but once you get up into that higher rpm powerband....watch out
No amount of tuning will change the fact that more horsepower requires more fuel. You're moving more air/fuel at all rpms, and your staying at higher rpms more often because that's where your stall will put you....right in your powerband. so from all your mods, you lost 5mpg. okay. so say 3mpg is from the cam, 2 mpg is from the stall and all your other mods combined. okay, well 3mpg is a reasonable loss from gears. so the gears and cam should have a relatively similar mpg loss. with gears though, you gain 1-2 tenths. with a cam you could potentially gain half a second plus! now what is the better mod for the money? jesus, this is what i've been saying all along. gears is wasted money in this situation. go through my posts and see how many times i said other mods can yield better results for the money. that is my point. spend the money elsewhere. no one can read, i swear to god.
more horsepower doesn't necessarily require more fuel either. you can do mods that increase the motor's efficiency. LT's, exhaust work, a ram air, a lid without baffles ALL increase mileage and horsepower for the sole fact the motor is more efficient. heads can do this too. again, it's the cam that mixes the fuel and kills your mpg.
Better mod for the money?? You do know that a cam swap on a bolt-on a4 car done the right way can cost between $2000-3000 right? Let's be optimistic and say a 224/224 cam/supporting mods, converter and tune will give you a 1 second et drop, and you already have headers/exhaust and slicks on the car.
cam:$350
pushrods:$150
springs:$150
oil pump:$100 (optional)
pulley/belts:$200 (optional, but dumb not to since the stocker's comin off anyhow)
stall converter: $450-700, depending on manufacturer
tools, fluids, misc:$75-100 give or take
tune: $500
TOTAL: $1775-$2250
This is all assuming you're doing the install yourself. Since you're counting labor in the $500 price for a gear swap, we'll do the same here....that'll add $600-800 onto the bill (obviously subject to location) bringing it to $2675-$3000. I know a cam/converter swap can be done cheaper, but I can do a gear swap for less than $200 so we won't open that can of worms
. We'll round a lil and say $2800 for the final bill for all new parts installed. After it's done and we've gained our 1 second et improvement we've spent $280 per 1 tenth reduction in et. Let's once again be optimistic and say a gear swap from 2.73 to 3.73 will net you 2 tenths improvement in et and it costs us $500 for parts/install. Looks like $250 per 1 tenth reduction.
Gears are not a bad mod nor a waste of money. I personally think 3.73's are an excellent ratio for a stalled ls1.
Guy that started this thread: If you're putting a big stall in your car, you apparently aren't worried too much about a small mileage decrease. Get the gears, you'll love em. Tenths add up one at a time.
[/my input]
cam:$350
pushrods:$150
springs:$150
tune: $500
TOTAL: $1775-$2250
[/my input]
cam:$350
pushrods:$150
springs:$150
tune: $500
TOTAL: $1775-$2250
[/my input]
add on $350 for a good set of m/t drag radials (to my door) that will mount on your stock 16" rims. i just got mine saturday and all i can say is wow.
