TCI Lockup Clutches Suck
Old Jul 10, 2006 | 05:02 PM
2xLS1's Avatar
Default TCI Lockup Clutches Suck
Getting ready to pull a TCI SSF3500 out again because the lock up clutch is slipping AGAIN This is number 2 in the same car. The first one lasted less than 1K miles before it started slipping. This one has around 4K miles on it. Setting P1870 AGAIN. Number 3 will be a Yank.
Old Jul 10, 2006 | 06:00 PM
ramairws6's Avatar
Just was waundering if you upgraded to the billet cover on the second convertor? It has a larger apply area and is a much better piece as I was told, more money also?! Traver
Old Jul 10, 2006 | 06:06 PM
2xLS1's Avatar
First one was sent back to TCI and was replaced with the same kind. If it takes an upgrade to make it reliable, they should not sell the original. This is not in my car, but a friends who has to pay for R&R each time also.
Old Jul 10, 2006 | 07:30 PM
JNorris's Avatar
Moderator
Is the car a daily driver or is it weekend racer?
Old Jul 10, 2006 | 07:57 PM
2xLS1's Avatar
It's an occasional driver. Never been to the track. Converters have never been manually locked on dyno or otherwise. #1 went in a fresh rebuilt tranny. After talking to the tranny builder today, he said he has seen 4 other TCIs in just the last month with the same problem. He will no longer recomend them either. The owner of the car is a cop so he doesn't even street race. What pisses me off is I have only ever run Yanks in my cars with good results and I'm the one that recomended he go with a TCI to save him a little money. He's spent more than the Yank would have cost in R&R costs.
Old Jul 10, 2006 | 09:29 PM
JNorris's Avatar
Moderator
Well that sucks....I trust you have talked with TCI about this problem.
John
Old Jul 10, 2006 | 09:38 PM
2xLS1's Avatar
I'm sure TCI will fix or replace this one just like they did #1. It just won't go back in the car. That doesn't help him much with the R&R costs.
Old Jul 10, 2006 | 10:04 PM
SSwanner's Avatar
sorry to hear about your troubles..... if it makes you feel any better i have/had 3 TCI's when i was still in the 4L60E's. the first one made it 2 days, second one made it about 3 months, the last one had the billet cover and all upgrades (they are excellent people to deal with, just a flaw with these converters) and it slipped worse/faster than the first two did. i was pissed so i just kept driving it. it was so bad with the cruise set at about 75 on the I-state (3.73's) it would jerk the car going up an incline. after that i toasted the max evil stg. III and went to a th350. tci swapped out the converter for a transbrake valvebody for it.
Old Jul 11, 2006 | 03:42 AM
2002_Z28_Six_Speed's Avatar
TCI uses paper clutch in many converter models. I am not sure if they use anything else at all. Get a converter with a real carbon cermanic clutch instead of paper.
Old Jul 11, 2006 | 08:40 AM
BlackHawk T/A's Avatar
Paper???
Old Jul 11, 2006 | 10:13 AM
Joel_SS's Avatar
My TCI is doing the same thing. Proablly going with a Yank.. I have good luck with them in the past and my wifes TA has one with zero problems..
Question, If I keep driving the car like this will it damage my tranny?
Old Jul 11, 2006 | 11:47 AM
2xLS1's Avatar
At speeds where the converter should be locked and it is slipping, the trans fluid temp will get real high. On the car I'm talking about, on about a 40 mile interstate trip to my house, by the time the car got here the trans fluid temps got to 250* and the coolant temps were over 230*. It was a 100* day here though.
Old Jul 11, 2006 | 12:06 PM
franny40's Avatar
i remember when everyone was on tci's nuts. i bought a ssf 3500 because of all the great things people said about them, but that being said i too had problems with the tc locking up, then the prolem just went away, i have taken my car to the strip many times and have not had a problem yet. but i will probably buy a yank once this one goes.
Old Jul 11, 2006 | 12:17 PM
Joel_SS's Avatar
cool thanks.. So is it pretty safe to assume that my Lock clutch is toast and it is not me solenoid or anything else. I guess I need to get is replaced ASAP!
Old Jul 12, 2006 | 11:30 PM
ChevPower's Avatar
Well good luck with what ever you do. O by they way i have the top of the line PY3600 YANK the converter clutch went out in less than 1k miles I have it for sale as soon as Yank gets it back to me I'm going back to a TCI
Old Jul 13, 2006 | 10:34 AM
jimmyblue's Avatar
Moderator
I was able to gimp along for a couple of years by upping
the line pressure at lower throttle areas, to give the
small clutch more to work with. Latest version of HPTuners
adds several "General Pressure" handles that directly bump
line when TCC is applied, a more sophisticated way to get
holding power. The clutch just is what it is, and is not the
same size as stock tune assumes for pressure needs.
Hard friction slip is the deadly heat maker, way worse than
fluidic losses in the converter hydrodynamic part (and also
not carried off to the cooler, so efficiently as fluid-heating
processes). When the trans slips up grade, consider yourself
fukt very shortly. Glazing becomes very likely, if that is the
material system's response to overtemp (here, ceramics are
your buddy, they're much higher temperature-stable).
A larger, stronger clutch -can- be built into a 10" converter
and this is what made me dollar up for the Fuddle middle-
grade ("High Performance Street") model. TCC qualities are
usually given little weight in converter mfrs' specs / mktg
material, though. You have to dig for it in most cases and
sometimes it just comes up mud.
Old Jul 13, 2006 | 11:41 PM
Originally Posted by jimmyblue
hydrodynamic part
You do know hydro is water and hydra is oil right??????
Old Jul 15, 2006 | 12:55 AM
Formulated's Avatar
Clutch slippage seems to be the most common problem I read about in this forum. I'm wondering if it's just the byproduct of using 10" and smaller converters. For that reason I've considered backing down on the stall speed and getting an 11" converter like the TCI breakaway. Hughes also has a 10" converter with a 12" clutch. The only drawback is the total mass and inertia of the converter, but it may be a reasonable trade off for a daily driver, unless you like changing converters.
Old Jul 16, 2006 | 03:11 PM
RevGTO's Avatar
Pontiacerator
This is why manufacturers like Vig take care to use super-durable clutch material. In reading this forum for three years, I've never heard of a Vig failure. For the same reason, reports of Yank clutch failures are also uncommon. As Jimmyblue said, going for the upgraded clutch on the Fuddle is probably worth it. So a small converter can be built with a stout clutch; it just requires more expensive materials and a billet cover which drives up the cost.
Old Jul 17, 2006 | 11:57 AM
PREDATOR-Z's Avatar
Had the same problem 2 years ago with my TCI 3500. although they were keen to help, I decided to just go with VIG. Sould have done that from day 1.
