4l60e a4 the same trans in 95 s10?
TireFryer
95 was in the crossover years to the 4L60E, so make sure it is the E version, I don't know when the trucks switched.
<small>[ June 05, 2002, 01:38 PM: Message edited by: Chris Spiess ]</small>
so about the only thing needed would be the tail shaft off of mine to make it work? how can I be sure it's a 4l60E?
Are you saying that none of those cars use the 4L80e or just not in that year?
GM uses the 4L80 in suburbans and some other truck applications, but I don't know in 1995.
<strong>So I can get a PI2800 for my Sonoma? Cool. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It might actually be able to get out of its own way with a 'verter. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
God, I hated my 4.3L blazer. <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
John <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ June 05, 2002, 08:34 PM: Message edited by: XLR8NSS ]</small>
The tranny in your TA will have the 3 piece case (removable bellhousing) while the S10 tranny will NOT, as well as the 4wd issues previously mentioned. I believe the input shaft is a different length as well. It (bolting the S10 tranny up) would be similar to what's required to bolt up a turbo 350 or 400 properly to an LS1 - custom converter, stiffener/adaptor plate, etc...
Hope this helps. I'm quite certain of my facts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong>Chris:
GM uses the 4L80 in suburbans and some other truck applications, but I don't know in 1995.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ragtop,
Sorry, didn't mean to make it sound like all full size truck apps used the 60. You are correct, some combos do come with the 80. Although most of the vehicles (half-tons) you find will be have 60s in them.
I was not aware of the multi-piece case issue. Thanks, rob
