View Poll Results: YANK/VIG 36OO
YANK SS3600
59.08%
VIG 3600
40.92%
Voters: 303. You may not vote on this poll
Yank/ Vig 3600
Old Nov 2, 2006 | 11:16 AM
  #41
blue2000Z28's Avatar
You know ALL of this is THERE own OPINION. Its like trying to compare a ford and a chevy. Every body with Yank is saying Yank, and everybody with vig is saying vig. Heres what I would do if I were you. It is going to be expensive but oh well: Get which ever one you want, vig or yank. Then run it. Then find a buddy or somebody on a local bord with the different converter. Then drive it or run it. Find out which you want. All im doing is calling FLT. Asking them about my trans and telling them all my mods, then if they say the 4l80 is good then Im going to see which converter they say. Same with the 4l60 e if they say that will work. Its all up to you.
Old Nov 3, 2006 | 08:31 PM
  #42
JersZ28's Avatar
GO YANK i have the ss3600 and love it. My car is a dd and sees some track time.
Old Nov 13, 2006 | 10:26 AM
  #43
PREDATOR-Z's Avatar
FLT is a VIG dealer so i'll give one guess.
Old Nov 14, 2006 | 06:58 PM
  #44
Lythropus's Avatar
I was reading through this post and still have my stock stall. So your telling me that a 3000rpm stall won't let you roll foward in traffic? I kinda like how my call rolls up small hills at idle without any throttle.
Old Nov 14, 2006 | 07:28 PM
  #45
Roarin_8's Avatar
If the ground is level, the car won't move at all. If you're on a hill, depending on how steep it is, you may actually roll backwards like the car was a manual. The larger the stall, the greater the effect. Once you get a bigger cam, the car will move like it did before you changed the stall. It all depends on cam selection, stall rating and gearing.
Old Nov 15, 2006 | 12:21 PM
  #46
Lythropus's Avatar
So say i install a TC around 3200 or so with a high STR (2.5-2.7) with 3.73 gears, how big of a cam would it take to act like normal, besides the lope?
Old Nov 16, 2006 | 08:51 AM
  #47
Roarin_8's Avatar
I can't say. The cam I have is pretty big and at idle it's at 950rpms, which would explain why the car moves as soon as I let off the brakes. You can try searching PatrickG's posts, since he's done alot of cam swaps in his car and has given detailed info about them. Hope that helps.
Old Nov 16, 2006 | 09:38 PM
  #48
TonyGXP's Avatar
Is there any truth to the rumor I heard from some of my friends that when the Yanks "go" they take the whole trans with it?? as opposed to the Vig?? I just installed a TCI MaxEffort StreetFighter 3200 and have to remove it due to a vibration and some other funky noises and am trying to decide which is better, I know the Vig is a few $$ more, but that is not a problem now, I will spend what I have to to get the best one, period... how much less "Efficient" is a Vig than a Yank, if that's true?
Old Nov 16, 2006 | 10:41 PM
  #49
Roarin_8's Avatar
I personally haven't been in that situation so I can't say.
Old Nov 19, 2006 | 11:44 PM
  #50
tbick's Avatar
i dont have a vig or yank, but make sure the converter you get has a str of 2.0 or more, my fuddle 3600 1.8str (was on the car when i bought it) feels very loose when trying to drive conservatively. it feels great when i mash the gas pedal and it is very efficient up high, but driving around 30 mph and going up hills is between 2500-3000 rpms, it could be improved by getting a tune or putting in lower gears, or buying another converter. just a warning, as long as the str is high enough i think almost any stall can drive around town fine.
Old Nov 21, 2006 | 03:37 PM
  #51
1320FEVER's Avatar
I just junked my fuddle for a yank pt4000. I installed it last weekend and I'm very happy with it. It feels like it gained 80 hp.
Old Nov 29, 2006 | 05:14 PM
  #52
chris93266's Avatar
my pro yank 3600 feels like stock.
Old Nov 29, 2006 | 07:53 PM
  #53
TonyGXP's Avatar
My Vig 3400 9.5" MultiDisc 3plate feels almost like stock, needs less than 2k to get it moving well from a stop, very impressed.. Flashes 3400 on the Nose! brake stalls 3200.. lay into it and it's a pure animal.. anything under 20mph and it roasts the 20's like they were bicycle tires
Old Nov 29, 2006 | 09:24 PM
  #54
00slowredz's Avatar
thats the kinda post i like to read. im very nervous about spending a lot of money on a stall and hating it. thats awesome, roasts the 20s like bicycle tires
Old Nov 30, 2006 | 10:42 AM
  #55
chris93266's Avatar
btw when i said stock i meant STOCK moves from idle. now that i have a large cam, my idle is set to 950rpm. i can idle to 30mph. i actually want more stall and am doing an a3 swap.
Old Nov 30, 2006 | 11:57 PM
  #56
2000SLPZ28's Avatar
you'll distroy your tranny if you dont build it. but if you wanna do that, i got a yank 3600 for sell on ebay if you wanna look at it.
Old Dec 1, 2006 | 12:34 AM
  #57
myfast70's Avatar
Can you post a link to your auction for the Yank.
Old Dec 1, 2006 | 12:37 AM
  #58
myfast70's Avatar
Originally Posted by TXZ28LS1
im debating between the 2. i plan on going with X1 230/227 cam. which would be more suited for a daily driver street car? it will never see the track. i want something, that will be nice and tight when driving around to where it seems as though i dont have a stall. which would be better quality? who has actually ran both? any pros and cons?
Which one did you end up with?
Old Dec 1, 2006 | 10:30 AM
  #59
2000SLPZ28's Avatar
http://cgi.ebay.com/ebaymotors/Yank-...QQcmdZViewItem
i know the pics look a little dirty, but its where i keep a little tranny oil in it.
Old Dec 1, 2006 | 01:39 PM
  #60
TonyGXP's Avatar
what did you replace the Yank with?
