Solve My 2-3 Shift Problem And I will Send You $50
To only one person of course, first one to solve it gets the cash.
Here is what is happeing:
I swapped out my 10 bolt 3:23 for a 9", 3:89. After the break in period I took the car in to have the car tuned. When on the dyno the car would not shift 2-3 at WOT. It just kept banging the limiter.
So, I was told they thought the 2-3 clutch packs were shot. So, I got a new trans and guess what. Still same thing shifts fine 1-2 but bangs the 2-3 shift and will NOT shift into 3 at WOT. Even in I lift off the gas a bit and then get back on it, same thing.
The person that did the tune has done a TON of high end, high HP LS1 cars. So, what can be causing this issue. I am so
right now I can't see straight.
The shifts were fine before I had the rear done and the tune.
The MPH and RPM shift points are currently set at the following:
Shifts MPH RPM Rev Limiter
1-2 32 5,900 6,800
2-3 65 5,900 6,800
3-4 125 5,900 6,800
What the hell can be the problem?
I appreciate any help!
Bill
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
1-2 32 5,900 6,800
2-3 65 5,900 6,800
3-4 125 5,900 6,800
Bill
So, I was told they thought the 2-3 clutch packs were shot. I wanted to upgrade my tarns anyway. So, I got a new trans and guess what. Still same thing shifts fine 1-2 but bangs the 2-3 shift and will NOT shift into 3 at WOT. Even in I lift off the gas a bit and then get back on it, same thing.
Shifts MPH RPM
1-2 32 5,900
2-3 65 5,900
3-4 125 5,900
Bill
Shifts MPH RPM
1-2 32 5,900
2-3 65 5,900
3-4 125 5,900
Bill
You could have a gear ratio error and the MPH is OVeruling the RPM values. Do you have the table data handy ?
th350 will solve the problem, do i win ..j\k
a buddy of mine just had the same problem with the same gears.. i would try the line pressure if you have a shift kit then you need to tune the line pressure to stock too much line pressure can cause the cylinode (sp lol) to stick...
Originally Posted by CollinsAutomotive
thats easy. the shift MPH is overulling the Shift RPM. You are always better setting MPH lower then the intended shift RPM as once the MPH is reached logic wise the PCM will wiat to shift then trans until the RPM come to the shift point. What is the shift timming table and shift pressure like ?
Can I get your number.
Thanks,
Bill
more info to add to this is it NEVER hit the rev limiter on teh 2-3 shift until on the dyno after the break in period for the rear end/gears. bill, did you ever floor the car before returning to that shop for the dyno tune?
and, the other part is after this happened on the dyno, they did try and mess around with the mph/shift rpm for the 2/3 shift. but Im not sure if they had the mph lowered BELOW the actual mph@Xrpm in that gear. I know he told me they lowered the rpm and mph for the 2-3 shift with out getting it to shift.
part 3, it has a trans go shift kit (like the old trans does) and this one has 3 washers in it since it has a 3800 stall. Im not sure how many washers the old one has in it. if the line press. is too high due to having 3 washers instead of the norm. 2 washers (under the accumulator)for street cars, why does the 1-2 shift consistently work, and the 2-3 shift does not? do you think we should try only 2 washers? what is stock line press and how could I adj. it if the washer does not lower it enough?
Originally Posted by Vince @ FLT
The washers for the 1-2 accumulator have nothing to do with the 2-3 shift. Look at the tune and see if the new rear end ratio was entered.
The new gear was entered.
Originally Posted by Boodyrider
LMAO, guess you won't be using them for a tune again.
I just need this to be solved ASAP.
I just don't understand how 1-2 works so well, 2-3 not at all?
Thanks Chris!
Bill
Hey, I was going to call you and see if you could get me on the dyno and solve this issue. I am about to sell the damm car. I am going to email the place that did the tune and see if they will email me the file. It was done in EFI Live. Can you read that? Can you play with my shift points with your software without over riding my tune?
Thanks,
Bill
Thanks,
Bill
Im chris, the white LT1 Z down the road from your shop. stopped by several times, sure you'd recognize me when you see me.
will be bringing dads MECHAM TA back for a tune in a few weeks. need to notch the pistons before it all goes back together. hey, you got a tool for notching LS1 pistons? I ended up goin with a diff. cam we discussed due to wanting lower max power RPM. Matt said you stopped pulling at 6600rpm I think was the # and it was still goin up but was running out of fuel due to his stock inj.s and pump. gonna put in 30lb inj.s in dads car and will see how the stock pump hangs after you tune it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by WHPLASH
Everyone knows about you. LOL You tuned my dads 02 convertable Vette too (Spectra car).
Your going to regret the camshaft thing. Matts car is stupid. Wish i would have had a better tire to stick on it. his car peaked at 6450.I do not have a flycutting tool though. Sorry.
I'm way out of my league here, but I think sometimes there must be computer issues that result in funny shift behavior.
I worked with a tuner for quite some time after my car had a simple 2.73 to 3.42 swap... and nothing except for experimentation with the shift settings worked.
In the end the shift tables make no sense (how they are set). The numbers don't line up with how the car behaves, but the ratios are consistent. That is it's like everything is sort of globally off and the behavior is also not consistent based upon the mph+rpm needing to be met.
At first I suspected something simple but the guy tried everything and triple check things time and time again. Even as straightforward as it should (and typically was according to the tuner) we simply could not get my car to behave properly.
You are so far beyond me on mods I feel foolish suggesting this, but do you have a way to try setting your 2-3 shift rpm at something terribly low, like 5000rpm? Only with experimentation were we able to eventually get my car working as it should.
The way it is set up the numbers in the shift/kickdown tables don't line up with what is actually happening, but the car behaves properly. The tuner said this was unheard of and had no solution.
Are your kick downs messed up as well?
