Built tranny before Torquer v2 install?
Old Nov 10, 2006 | 08:29 PM
fastSS2002's Avatar
Default Built tranny before Torquer v2 install?
Im just about ready to install my Torquer v2 and was starting to get a little paranoid about if my tranny will hold.Should i save money and get a built 4l60e before i put this cam in?........Any guys with similar cams on stock trannys have any input on this?........Thanks
Old Nov 11, 2006 | 05:58 PM
fastSS2002's Avatar
Come on guys...no one has any advice?...no one has a big cam with stock 4l60e?
Old Nov 11, 2006 | 07:07 PM
performabuilt's Avatar
LS1Tech Sponsor
Hi personally and not because im trying to sell a tranny , if money was there I would do the tranny in the beginning , I know its not as fun as a cam of gears ect but its what everything must travel through and nothing sucks worse that getting the power you wanted only to have the trans crap out on you before you get to play
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 11, 2006 | 07:26 PM
fastSS2002's Avatar
thanks for the input,i was actually just looking at your site and was thinking of doing the tranny first.What do you recomend for my application,Level 1 or level 2? Heads will be comming next.
Old Nov 11, 2006 | 07:34 PM
WeeWolf's Avatar
if i had to do it over again i would. been fighting with the trans since install of the cam.
Old Nov 11, 2006 | 09:12 PM
LS1Tech Sponsor
level2 have room to grow
__________________
Call 888-744-6542
Old Nov 11, 2006 | 09:18 PM
GregWS6&z28's Avatar
i broke a hardened 4L65E output shaft on my second run with my torquer 2 cam
Old Nov 11, 2006 | 09:44 PM
LS1Tech Sponsor
Ouch! I havent seen to many of those break even stock over the years , In fact only one ever but it had strees cracks when magnafluxed
__________________
Call 888-744-6542
