Will a 4l60e from an 98+ ls1 car bolt up to an lt1?
as the topic states, will the 4l60e from the 98+ ls1 cars bolt up to an lt1?
what about the converter... do they use the same torque converter?
thanks for any help that can be provided.
i have heard of a guy from corvette forum who swapped an ls1 for his lt1 and all he had to do was use an ls1 converter.. i also know the vss is different.. that is all. trying to find out the same thing myself but it seeems that nobody knows...
no.. i was saying he swapped his lt1 motor out with an ls1 and used the stock c4 corvette transmission behind an ls1. he had to buy an ls1 converter to make the swap work.. the ls1 flywheel/ flexpate bolt hole diameter is not the same so if you were to try the swap you would have to use the lt1 converter in the ls1 tranny.
I think the C5 transmission and the LT1 transmission are similar. Notice on Gearstar's website they have their transmissions listed but they will also have C5 listed on the first one and then the second one will say "for LS1 applications."
LT1 4L60E....28spline shafts, different bolt arrangement on the Bell housings, and the electronics changed a bit from the LT1s to LS1s....the LS1 4L60Es have 30 spline shafts....now if im not mistaken..you could swap the LS1 internals over to your LT1 based 4L60 alongwith the flexplate and the use of a LS1 Verter....but that is just hear say...never actually seen it done..
Originally Posted by GreatWhiteZ28
LT1 4L60E....28spline shafts, different bolt arrangement on the Bell housings, and the electronics changed a bit from the LT1s to LS1s....the LS1 4L60Es have 30 spline shafts....now if im not mistaken..you could swap the LS1 internals over to your LT1 based 4L60 along with the flexplate and the use of a LS1 Verter....but that is just hear say...never actually seen it done..
