how efficient is the th400 compared to the 4l60?
Old Dec 17, 2006 | 09:17 AM
  #41
TNTaddict's Avatar
Originally Posted by JL ws-6
th350 parts are a little lighter, but to build one to take the same power as a th400 will not be cheap. If you already have a th400, I wouldnt' bother unless you are tryignto get every last .1 out of the car.. because realisticially, that's about what you are talking about getting.
BY gettinga custom made converter to your car (not sure what you are running now) you'd stand to probably gain more then swapping to a th350
i ran 10.9@123.3 mph .....3320lb...(347ci H/C N/A with Th400)...
still got alot in the car....looking for a low-mid 10's N/A ....
if th350 will pull 0.1 that would be great
thx alot..
Old Dec 18, 2006 | 01:06 AM
  #42
DanZ28's Avatar
Had: stock 3.23 rearend, 26" slicks, aluminum DS, built 4l60e , 4000K stall, 1800' DA, ran 11.4 at 119mph with 1.60 sixty.
Have: 12 bolt with 4.10's, 28" slicks, steel DS, TH400, 4800 stall, 2500' DA, ran 10.9 at 125mph with 1.60 sixty.
I'll take a TH400 over the 4l60e any day. I don't even care about the dyno numbers, the track is what you need to use for the real test...
Dan
Old Dec 18, 2006 | 03:20 AM
  #43
SuperZ's Avatar
Dan
wow thats awesome.Did you add power to the car also when the th400 was in there
Old Dec 18, 2006 | 07:41 AM
  #44
TNTaddict's Avatar
Dan
woow....so, i'll start through some light wt parts in my th400 and that's it...
thanks DanZ28.....
Old Dec 18, 2006 | 10:23 AM
  #45
Zombie's Avatar
Originally Posted by ls1408cp
I did it with the numbers in your sig. You woulds have to be 3900lbs. Are you just guessing?
It's around 3800 with me in it. My only weight reduction is the removal of the front sway bar. I've done nothing but make the car heavier and it it doesn't even have a bar in it yet I don't use front runners at the track either, stock 17x9" wheels.
Old Dec 18, 2006 | 03:59 PM
  #46
DanZ28's Avatar
Didn't add any power. I couldn't believe the timeslip when I looked at it, especially the MPH for a TH400. I mean, I was hoping I would get a 10.9x, but it was hot out that day and didn't think I could pull it off. Haven't got a full run on the T-brake yet either.
With the same setup I have now except I had an M6, a smaller cam (about 10-15 less peak whp), 26" slicks, 2500' DA, about 100# heavier, I ran 11.7 at 120mph 1.70 sixty. Just thought I would throw that in there too.
Dan
