Aftermarket tranny controller
also running a cooler T-stat helps keep the heat down on a cruise considering the stock cooler is submerged in the coolant in the bottom of the radiator
..this is the one (amazon poped up you can get it cheaper througha vendor on here w/o a doubt)
http://www.amazon.com/dp/B000C3BBKS/...ectronicssh-20
I don't think anyone read your message...they responsed about trans coolers and pans. You had asked about trans controllers.
I've had good luck with the TCI controllers for the 4L60E. They're fully programmable as far as shift firmness, part throttle and WOT shift points, lockup control and more. They're also plug and play...the easiest one to install on the market. I've got one for sale if you're interested...just PM me.
Thanks.
Rob
As far as controllers I've seen a Hughes unit on Powerblock TV thats was simple, and looking at a TCI. PM comin to u.
