Trans Temp gauge Help
I have read the port on the tranny case is not very accurate.
And you really dont need to see how cool you can get the fluid, but how hot the fluid is getting. Put it in the feed line FROM the tranny TO the radiator. Then you will see how hot the fluid is getting.
Hope that helps. My gauges just got here today too. Ill post pics once they are installed. I got the B&M Blackouts, should be sweet!
1.Return line before cooler
2.Test port
3.Oil pan
you pick, any of thoes will be fine.
here is a link for the test port
http://www.black98.cz28.com/photo6.html
2.Test port
3.Oil pan
My experience by testing each location is only 10-15* at most difference(have other gm cars too and its the same) also checked temps with a logger and read the same as the test port.
