How hard can it be to rebuild a th350?
Old May 23, 2007 | 09:20 PM
CHVYMAN's Avatar
Default How hard can it be to rebuild a th350?
This is going to be my third th350 tranny and im sick of paying to get it redone, So, I decided to buy a book and do it my self. I have no idea why this tranny keeps going out, MAYBE PINION ANGLE, Would this cause it to go out? I need to learn how to adjust for pinion angle i think. LOL. Whatever, I think it was a crap rebuild each time. To top it off, i have absolutely no idea what im doing when it comes to tranys, except for feeling down there if you now what i mean.
Here is the setup, TH350 with transbreak, 9in tailshaft, manual reverse valve body, BMR crossmember, custom steel drive shaft, BMR torque arm, Getto riged stock tranny mount, stock shifter with Getto adjustments, TCI SSF 4000rpm stall, TCI flexpate, No VSS plugs, running the tranny stright off a cooler, B&M super cooler.
This is how i know this tranny is done for, 1st gear is good, 2nd goes in for a second and throws it's self into third without me shifting it. Third gear is good.
This is what im going to buy to rebuild, TCI pro super overhaul kit. also plan on sending my converter back to TCI for a cleaning. Plus im cleaning cooler with compressed air.
I think im overhead but i have to learn. Someone please disagree.
Old May 23, 2007 | 11:00 PM
5_02ls1's Avatar
its really the easiest trannys to rebuild...when you do it make sure you have a bench long enough were you can lay the peices in order just the way they came out...i done my 1st one in highscool...its been a few years since ive touched one...the th400 is also easy to do....and you will need a press and a pump puller
Old May 23, 2007 | 11:14 PM
performabuilt's Avatar
LS1Tech Sponsor
Its and excellent starter trans, get a book and follow the directions carefully
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 24, 2007 | 01:38 AM
CHVYMAN's Avatar
Im thinking C-clamps might work as a press and a home made modified screw driver for a pump puller.
Old May 24, 2007 | 01:41 AM
CHVYMAN's Avatar
Thats what I figured, not like a 4l60e... I hear those are a pain. THanks for the self esteem builder.
Old May 24, 2007 | 01:44 AM
CHVYMAN's Avatar
Does this sound right, Myth or fact, Welding the spring inside the tranny for xtra durability??? Maybe iam just hearing things.
Old May 24, 2007 | 06:25 AM
8a8mfh's Avatar
"the" spring? where did you hear this?
Old May 24, 2007 | 06:57 AM
slow14U's Avatar
I like this guy. Ghetto rigged stock tranny mount, ghetto adjusting shifter, modified screwdriver for a puller and c-clamps for a press. Any more tips?
Old May 24, 2007 | 08:15 AM
98Z28CobraKiller's Avatar
Restricted User
Nothing like having the wrong tool for the job
Old May 24, 2007 | 08:38 AM
LS1Tech Sponsor
I rebuilt my 1st 350 when I was 16 years old. 2 long screw drivers. 1/2 inch socket and rachet,9/16 wrench. Ice pick .Pair of crazy joes wrong snap ring pliers, Compression tool was a freind with two metal pipes. removed the pump by putting two 3/8 thread bolts in the threaded part of pump cover and using a claw hammer.and a feeler guage to install seals and measure clearance. Those were the days lol. But hey it worked and got my broke *** 16 year old self driving again lol
__________________
Call 888-744-6542
Old May 24, 2007 | 09:46 AM
lionelc-5's Avatar
You can do a 350, like some stated befor it is the easiest to rebuild. As far as pulling the front pump, you can use two bolts and a piece of chain. Put the bolt though the last eye in the chain and screw the bolt into the front pump. Make sure you have plenty of threads in the pump, and use the chain as a kina slide hammer.
The reverse piston will be kina tricky to pull , but can be done with two long screwdrivers and a friend to help. But just get a good pair of snapring plires. It is not worth fighting with the cheap ones. Get some bluepoint or snapon ones.
Old May 24, 2007 | 08:03 PM
CHVYMAN's Avatar
Nothing like beating high budget race cars with good ole know how and big 's. If life were fair I'd have Jessica Alba handing me 13 and 15 mm sockets in a CHEVY swimsuit.
Old May 24, 2007 | 08:12 PM
CHVYMAN's Avatar
The return springs, to keep them from popping out in high performance usage.
Old May 24, 2007 | 08:16 PM
CHVYMAN's Avatar
LOL.
Old May 24, 2007 | 09:37 PM
8a8mfh's Avatar
You're a ******* idiot, I wish guys like you could work a camera and do a th350 build up that could be used as a sticky. Some ******** in a clown suit, C clamps, screw drivers for spring depressors and welded clutch return springs, please take some pics of your progress.
Old May 25, 2007 | 12:19 AM
MESS's Avatar
sounds like my tool box !
Old May 25, 2007 | 12:55 AM
CHVYMAN's Avatar
Thanks for the complements.. Jerk off. I didnt know LS1tech was only for the privileged. CANT afford to keep taking my tranny into the shop all the time because I actually race my car and not my mouth like others. SPONSER ME BIATCH if it bothers you so much.
My thread might be stupid, but it has definitely helped me out, it has inspired me to do something I thought I could not do. LOL.
Old May 25, 2007 | 05:40 AM
8a8mfh's Avatar
Ok then, if you live within 50 miles from 34983 I will build a th350 for you, no charge to you.
