4L60 tranny line question
Old Oct 28, 2002 | 08:50 AM
Joe99SS's Avatar
Default 4L60 tranny line question
OK, stupid question... Which tranny line is which coming out of the trans case on the 4L60E? Is the bottom line the return line?
Thanks...
<small>[ October 29, 2002, 09:01 AM: Message edited by: Joe99SS ]</small>
Old Oct 29, 2002 | 09:03 AM
Joe99SS's Avatar
Default Re: 4L60 tranny line question
bueller?
bueller??
Old Oct 29, 2002 | 10:34 AM
OBSSSD@work's Avatar
Follow the bottom line out of the radiator. That is the return.
Old Oct 29, 2002 | 11:53 AM
Joe99SS's Avatar
the lines aren't connected to the tranny... I need to know which goes where on the tranny itself...
Thanks for the reply though...
Old Oct 30, 2002 | 01:14 AM
CAT3's Avatar
Restricted User
The pressure line goes from the top of the trans to the bottom of the radiator, and of course the return bottom trans to top of rad. The pressure line is identified by the fact that the line has TWO high pressure fittings where it goes from the line to the hose and then hose back to line at the front of the vehicle. remove the top line from rad. to run into trans cooler. And yes, I just laid out under the car to verify. Good-Luck.
Charlie.
<small>[ October 30, 2002, 01:30 AM: Message edited by: CAT3 ]</small>
Old Oct 30, 2002 | 01:34 AM
CAT3's Avatar
Restricted User
OBSSSD, check your lines, maybe there are differences in the years, although I doubt it. If you take the bottom line off and start the car, you will notice fluid pumping from the line not the radiator, making this the pressure line, hence it has the pressure fittings on both ends of the hose / line connection. Unlike the return line from the top of the radiator which has ONE pressure fitting from line to hose and at the radiator side but from the hose back to line (working towards trans) it has a tension clamp.
Charlie.
Old Oct 30, 2002 | 07:36 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Good work, CAT3, I looked all through the Helms diagrams and couldn't find it.
Old Oct 30, 2002 | 04:46 PM
Joe99SS's Avatar
thanks guys! greatly appreciate it... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 30, 2002 | 09:29 PM
CAT3's Avatar
Restricted User
Anytime I can help I will. How about this, anyone have a slight surging when idling in gear but not park/neutral (maybe it is too slight to notice then?)? I checked EGR/vacuum leaks-changed plugs and will change wires friday, but anything else? posted in external also. TIA.
Charlie.
Old Oct 31, 2002 | 09:18 AM
Joe99SS's Avatar
sorry, can't help you there as I have surging all over the place until I'm fully warmed up with my big cam...
Old Nov 2, 2002 | 09:30 PM
2edybrd's Avatar
Yup, I got that surge. I notice it more when the weather is hot.I think it has something to do with the MAF sensor. I say this because a couple of years ago, I bought the SLP Temptricker module and all of sudden the car was surging very badly. SLP said they had never heard of that problem before but they took the part back and gave me credit anyhow. (Thanks SLP) I got a call from them a few days later and they asked if I had home ported my MAF ends , which I had. The best they could figure was that the increased volume of air was messing with the sensors. Who Knows? Maybe this is what your problem is, if you have a ported MAF?
