which tranny fluid is the best?
Old Aug 19, 2007 | 04:07 AM
Omega Doom's Avatar
Question which tranny fluid is the best?
I'm about to finally install my Yank 4200 stall, and just wanted to know which is the best tranny fluid for a stock 4l60 with a stall?
Old Aug 19, 2007 | 06:27 AM
Fbodynightmare's Avatar
Did you add an after market cooler..?
Old Aug 19, 2007 | 06:59 AM
Omega Doom's Avatar
of course! I got Hayden cooler that is suppose to be for mobileholmes!
Old Aug 19, 2007 | 08:05 AM
FLT's Avatar
FLT
Dexron III or equivalent here. No synthetics for me.
Old Aug 19, 2007 | 10:23 PM
electric_ta's Avatar
has anyone ever heard of dex VI we have it were i work and it says its compatible with all gm but just want to make sure before i put it in
Old Aug 20, 2007 | 12:07 AM
Stangkilr's Avatar
All the dealership are putting dex VI in transmissions now no matter what year. Its more $$ too.
Old Aug 20, 2007 | 01:25 AM
kewl well were i am i get 5 gal cans of it for basically nothing at all just wanted to make sure it would work with my lvl2
Old Aug 20, 2007 | 02:17 AM
Omega Doom's Avatar
interesting!
Old Aug 20, 2007 | 06:46 AM
FLT's Avatar
FLT
Dex VI is going to be the new oil that we are going to be seeing more of here shortly. It is just fine to use if you can not find the III.
Old Aug 20, 2007 | 10:54 AM
Omega Doom's Avatar
ok so..... III first then the VI would be the next choice?
Old Aug 20, 2007 | 01:42 PM
allthrottle&nobottle's Avatar
Dex VI user here..............better heat #s than III, Dexron-VI delivers ~two times the service life of Dexron-III H fluids
Buy it in the 1 gallon jug and pump away
A little info from last year..........
Info - Release of DEXRON VI Automatic Transmission Fluid (ATF) #04-07-30-037A - (Aug 19, 2005)
Release of DEXRON® VI Automatic Transmission Fluid (ATF)
2006 and Prior Cars and Light Duty Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2005 Saturn Relay
2005 and Prior Saturn L-Series
2005-2006 Saturn ION
2005-2006 Saturn VUE with 4T45-E
2005-2006 Saab 9-7X
Except 2006 and Prior Pontiac Vibe and Torrent
Except 2006 and Prior Chevrolet Aveo, Epica, Equinox, Optra
Except 2005-2006 Pontiac Wave
Except 2003-2005 Saturn ION with CVT or AF23 Only
Except 1991-2002 Saturn S-Series
Except 2006 and Prior Saturn VUE with CVT, AF33 or 5AT (MJ7/MJ8) Transmission Only
This bulletin is being revised to announce the use of DEXRON®-VI with the start of the 2006 model year production. Please discard Corporate Bulletin Number 04-07-30-037 (Section 07 -- Transmission/Transaxle).
DEXRON®-VI ATF
General Motors Powertrain has recently upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON®-III may use DEXRON®-VI as a replacement.
All 2006 and future models that use DEXRON®-VI are to be serviced with DEXRON®-VI fluid only.
DEXRON®-VI is an improvement over DEXRON®-III in the following area:
DEXRON®-VI
Extended Factory Fill For Life 160,000 km (100,000 mi) For Cars and Light Duty Trucks*
80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
Clutch Friction Stability Improved 100%
Clutch Durability Due To Fluid Improved 120%
Oil Film Thickness Increased 20%
Fluid Oxidation Improved 100%
Foam / Aeration Improved 150%
Shear Stability Improved 200%
* These ATF change intervals remain the same as DEXRON®-III for the time being.
2006 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of the J 45096 -- Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reservoir of the machine be purged of DEXRON®-III and filled with DEXRON®-VI.
Parts Information
Part Number Description
88861003 (US) DEXRON®-VI Auto Trans Fluid (1 Quart Bottle)
88861045 (US) DEXRON®-VI Auto Trans Fluid (1 Gallon Bottle)
88861046 (US) DEXRON®-VI Auto Trans Fluid (55 Gallon Drum)
88861004 (CA) DEXRON®-VI Auto Trans Fluid (1 Liter Bottle)
88861043 (CA) DEXRON®-VI Auto Trans Fluid (4 Liter Bottle)
88861044 (CA) DEXRON®-VI Auto Trans Fluid (205 Liter Drum)
Old Aug 20, 2007 | 04:27 PM
Strahley's Avatar
I use Type F in my th350. Been working fine for the ~1.5 years I've had this trans in the car
