good converter
Old Dec 28, 2002 | 12:53 AM
LS1 Brent's Avatar
Default good converter
what brand of converters is the best that sells a converter will a stall around 3200 rpm and is around $700?
Old Dec 28, 2002 | 11:36 AM
LS1 Brent's Avatar
Default Re: good converter
ttt
Old Dec 28, 2002 | 03:14 PM
LS1 Brent's Avatar
ttt
Old Dec 28, 2002 | 03:34 PM
12secSS's Avatar
Oddly, you're describing a Vig3200, they retail for $720. For deciding on a converter, you should list what mods you have and what intensions you have for using a converter. Race only? Street races only? Street/Strip? Other converters also fit this bill, but the Vig3200 is the most popular. I have one. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 28, 2002 | 03:38 PM
LS1 Brent's Avatar
mods include: SLP Loudmouth exhaust, and whisper lid, and 3.23 gears. the converter I am looking for is intended for street/strip. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Dec 28, 2002 | 04:29 PM
98SS Blackattack's Avatar
You could get a Tci or midwest for under 500. I have seen the PI Vig. for 699 by one of the sponsers. The 2800 will stall around 3200. The Vig 3200 will stall around 3600rpm. They are funny like that. IMO they are the best converters.
Old Dec 28, 2002 | 04:37 PM
Ragtop 99's Avatar
TCS makes a good converter and some of their models are in that price range.
Old Dec 29, 2002 | 09:23 AM
mikey's Avatar
LS1TECH Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1 Brent:
<strong> what brand of converters is the best that sells a converter will a stall around 3200 rpm and is around $700? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We sell the TCS converters (same one I run in my 9 second WS6). They are $689.00. Comes with unlimited lifetime re-stalls, a 3 year warantee and kevlar clutch. Quality is the best I have seen and I have used them all. See our web site for details.
Mikey
Old Dec 29, 2002 | 11:32 PM
LS1 Brent's Avatar
what does it mean by getting a converter re- stalled??
Old Dec 30, 2002 | 01:55 AM
Colonel's Avatar
It means changing the stall speed of the converter. Like making a 3500 converter stall to 4000 instead.
Old Dec 30, 2002 | 02:57 PM
LS1 Brent's Avatar
thanx for the info. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 31, 2002 | 02:41 AM
NX†C's Avatar
the vigilante converters utilize flash stall making their stall rates significantly higher than labled. the 2800 is a great street converter and performs well at the track. stalls to ~3200rpm and has a 2.5str (torque multiplier).
the vig3200 is a better street/strip converter and also handles nitrous very well. has a flash stall of ~3800rpm with a 2.0str. for a bigger all motor/strip verter anything from the vig3600 to 4000 is great but makes for a monotonous performer on the highway. flashes to ~4300 with a 2.0str. all the precision industries line come with a 2 year warranty and 1 free re-stall.
the yanks are very straight forward however i have never run one and can only say they do handle well after the price and with these there is no free re-stall.
as for TCI and everything else from SLP to Midwest i cannot say anything favorable nor lessening as i just have not used/ looked into it. hope this is of some use to you and best of luck.
Old Dec 31, 2002 | 11:10 AM
Colonel's Avatar
"the vigilante converters utilize flash stall making their stall rates significantly higher than labled."
If they used flash stall to rate their converters then they would be rated slightly HIGHER, not lower, than their true stall.
Fact is, they misrate their converters by a pretty substantial degree. I'm not saying that it's deception on their part. Maybe it's because they rate them at a much lower TQ than LS1s generally generate?
Old Jan 1, 2003 | 04:34 AM
NX†C's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">If they used flash stall to rate their converters then they would be rated slightly HIGHER, not lower, than their true stall.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im not saying anything about the actual representation per say of the converter, however instead am describing the characteristic of the converter.
with a yank converter you must brake stall to the desired rpm and hope your tires hold and you keep traction vs the precision converters which like to begin at the lower rpm to be flashed to well above the ACTUAL stall speed. that is simply their design.
