Best ATF?
Old Apr 2, 2008 | 12:55 PM
z28_YOU_HO's Avatar
Default Best ATF?
Whats the best make of transmission fluid..what would you go with im thinking castrol? not coastal
Old Apr 2, 2008 | 01:11 PM
LT1-DAN's Avatar
I like Valvoline Maxlife. It has worked great for me in all my cars.
Old Apr 2, 2008 | 01:33 PM
caldercay's Avatar
+1 on the V.M.
Old Apr 2, 2008 | 01:39 PM
Drake02's Avatar
I'm happy with Royal Purple.
Old Apr 2, 2008 | 01:44 PM
SLP99sscamaro's Avatar
+1 for royal purple the pricey purple fluid
Old Apr 2, 2008 | 01:45 PM
S P E E D's Avatar
Royal Purple here, use it in Everything from my WS6, Bike, Grand Cherokee, 89 Turbo Grand Prix.
I even use the Engine oil and Diff fluid also. Hell I even use the Water Wetter in the rad on my bike!
Old Apr 2, 2008 | 01:46 PM
jsteele90's Avatar
ive been using the castrol and it works fine.
Old Apr 2, 2008 | 01:49 PM
z28_YOU_HO's Avatar
i just picked up some castrol..the trans builder told me to use mercon V..But isnt that for Ford vehicles
Old Apr 2, 2008 | 01:54 PM
LT1-DAN's Avatar
DEX/MERC is recommended for most GM, Ford, Toyota and honda. It should tell you on the bottle.
Old Apr 2, 2008 | 01:59 PM
z28_YOU_HO's Avatar
it was sayin it was for fords. mercon 6 is for GM's i guess..5 is for fords??? idk im confused
Old Apr 2, 2008 | 02:09 PM
LT1-DAN's Avatar
You can use it if it is Mercon V.
Old Apr 2, 2008 | 02:10 PM
LT1-DAN's Avatar
GM is Dextron.
Old Apr 2, 2008 | 02:49 PM
SOMbitch's Avatar
If you have been running DIII I would recomend you stick with it. The later versions contain some synthetic and are more slippery. When I swapped mine out I immediately felt softer shifts from the new formula. 49K on car and tranny at the time. If your a new car with it from the factory or run it from day one in a rebuild I would think the new is better. I don't recommend swapping over though.
Old Apr 2, 2008 | 02:50 PM
z28_YOU_HO's Avatar
so i can use mercon V?? LOL
Old Apr 2, 2008 | 02:51 PM
z28_YOU_HO's Avatar
The tranny was just re-done..thats what the builder said to use in it....
Old Apr 2, 2008 | 02:54 PM
LT1-DAN's Avatar
Yes!! but why not just get the DEXTRON-3?
Old Apr 2, 2008 | 02:55 PM
GregWS6&z28's Avatar
yuo can use mercon 5 but it's moer expensive I believe. mercon 3 should work just fine. "ATF" is ford's fluid i believe
caldercay's Avatar
Mercon V is the newer specification for Mercon - Ford has been using Mercon V
in their vehicles for 8+ years.
You should be using a Dexron III. I've had both my tranny (FLT) and T.C (Yank)
folks tell me to use Dexron III. GM began factory-filling Dexron VI in April 2005.
Old Apr 2, 2008 | 03:01 PM
LT1-DAN's Avatar
ATF=Automatic Transmission Fluid.
Old Apr 2, 2008 | 03:06 PM
z28_YOU_HO's Avatar
thats what he told me to use so thats what i bought.. i just wanted to make sure i dont wanna have trans problems again..should i return it for the DEXTRON 3?
