People who swapped in a TH400 come in got some ???
Ok i recently swapped in th400 with a reverse VB, brake ect... in my 98Z that was once a 4l60e car. I'm looking to install a Cheetah shifter. I was wondering what wires go to the back up lights? Also is there any thing i need to do to the computer. I removed all the old cables and stuff and now the car will not start. I hooked up the linkage to the old shifter and the car will start but dies soon there after. Any info will be appreciated.
Thanks,
Joe
Thanks,
Joe
Not sure on this as I have not done mine yet, but I did do the M6 to A4 swap... There is two wires that are used for the Neutal safety switch.. This might be why the car dies....
TTT
TTT
The Bull
There are now wires on the Cheetah shifter specifically. Only the neutral safety switch. I'm devising a way to do this myself, but haven't really thought of it much so far.
Anyone know how to bypass the neutral safety switch?
The Bull
Stick or Auto? If it's a stick, just splice into the lower clutch position switch. Just disconnect the wire and splice in a piece to the neutral safety switch. If it's an auto, I have no idea. Send BlackSunshine00SS a message.
You just need to connnect the two wires... Which ones, you will need to look at a wiring diagram..
Joe
Super Moderator
If you do this, and you race in sanctioned events, you may get busted for no neutral safety switch. Not a concern for most, but if you run in brackets or something.
I am doing the MN6 - TH400 and using a stock shifter. A buddy of mine has devised a way to modify the stock shifter for 3 gears and reverse operation. He even has a replacement decal for the gear indicator!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
