Trans flush
Old May 29, 2008 | 09:22 PM
samson_420's Avatar
Default Trans flush
I have a 98 z28 with a a4. Currently it has 74k on it. I got the car at 65k, the guy I got it from said he had the transmission flushed(who knows when).
The fluid looks real good, just a bit bit brown/red.
Should I get it flushed? If so when?
Old May 29, 2008 | 09:47 PM
dpinson's Avatar
depends on how hard you drive it
but i would recommend it it just so you know for sure
burnt fluid = blown tranny
Old May 29, 2008 | 10:22 PM
staringback05's Avatar
wont hurt anything to do it...and you can put it in your records for the car now
Old May 29, 2008 | 10:31 PM
sslateron's Avatar
I'd git r dun, and filler er up with Amsoil transmission fluid, then you'll have peace of mind of knowing your covered by the best!
http://www.amsoil.com/catalog.aspx?code=ATF16-EA
Recommended for most automatic transmissions. Excellent in demanding environments such as towing, hauling or commercial use. Extends drain intervals. Saves time and costly maintenance expenses. Reduces operating temps by as much as 50°F.
SERVICE LIFE
AMSOIL Synthetic Automatic Transmission Fluid is recommended for use up to 50,000 miles under severe service* and up to 100,000 miles under normal service* or according to the vehicle manufacturer recommended intervals, whichever is longer. AMSOIL recommends thoroughly draining the transmission and flushing with new AMSOIL ATF to achieve a minimum 90% purity of new transmission fluid. Drain intervals may be extended further with oil analysis.
Old May 29, 2008 | 10:46 PM
QuietFlight's Avatar
only way to get a real good flush is to have someone use a machine tapped into the lines.
dropping the pan only does about 55-65%.
any quick lube has the machine. bring em about 18 quarts of whatever you would like to use in there and they can run it for you.
Old May 30, 2008 | 11:07 AM
samson_420's Avatar
I will see how much my local stealership here will charge me for a flush.
I might as well get it done, I flushed every other fluid.
Old May 30, 2008 | 11:10 AM
qwk93ta's Avatar
Plan on about $120 from a dealership......
buy the fluid yourself and see what a shop will charge you...if not theyll gig you on it
Old May 30, 2008 | 11:18 AM
deadcities's Avatar
You can flush it yourself if you're so inclined. Pop the send line to the tranny cooler and put a hose on the end, running in to a catch pan. Crank the car and it will start dumping the fluid out. Continuously add new fluid through the dipstick tube until the fluid running out is bright red. Reattach the tranny cooler line, and then top the fluid level off. Viola!
(It helps to have a second person on hand to add the fluid)
Old May 30, 2008 | 11:25 AM
samson_420's Avatar
That sounds easy enough. Which one of the two is the send line?
I still might have the stealership do it, 120 Bucks ain't too bad. But, I rather save 100 Bucks.
Old May 31, 2008 | 12:46 AM
samson_420's Avatar
Anyone?
Which line can I use to disconnect?
Old May 31, 2008 | 10:35 AM
wkdivr's Avatar
DO NOT FLUSH THE FLUID!!!!! In an older trans, flushing sometimes can dislodge some stuff that is actually holding your trans together. Just change fluid in the pan, and be done with it. On a high mileage trans it is NOT recommended to do a flush, or power flush, as some may call it.
Old May 31, 2008 | 10:47 AM
deadcities's Avatar
^^^---myth. Replacing the fluid isn't going to hurt a 4L60E.
samson- I can't remember off the top of my head which one it is. It's been a while since I've done it. You've got a 50/50 chance, and worse case is you have to reconnect one and pop the other one off.
Old May 31, 2008 | 11:55 AM
samson_420's Avatar
If I do it this way, it's not really a flush anyway. It is more of a fluid exchange.
I really don't want to pop the pan, since it is tight and does not leak.
Old May 31, 2008 | 01:53 PM
sslateron's Avatar
I'd go with the Syn. option from Jiffy Slube.
