Installing Built Trans...What Cooler to go with??!!
Old Sep 11, 2003 | 04:17 PM
JoSeY's Avatar
Default Installing Built Trans...What Cooler to go with??!!
I'm looking for seriously the best tranny cooler to go with...I live in Houston and it gets HOT down here...I'm looking to have this sucker stay COOOOOLLLL....I've been running a Multi-Disc 4000 Vig for 2yrs on the STOCK tranny with STOCK cooler and after 30,000 miles (110,000 total miles on the stock tranny though!) of N20 and Stage 2 Heads cam the sucker (Tranny) is starting to slip WAAAYYYY BAD....so It's time to upgrade. I want to put in a cooler and looking for tips on the the best cooler.
Old Sep 12, 2003 | 07:16 AM
JoSeY's Avatar
Default Re: Installing Built Trans...What Cooler to go with??!!
Come on guys!!! Just a lil bit of help!!!
Old Sep 12, 2003 | 08:03 AM
LS1x2's Avatar
Formerly 4mulaJoe
Just go with the biggest one you can fit that has a large fan on it. It will keep the fluid COOL. The coolers with the fans tend to cost 3x more. The regular large B&M's seem to be sufficient though.
Old Sep 12, 2003 | 03:51 PM
WILWAXU's Avatar
I went with a 24K B&M Supercooler.
Here's how to mount it with a Fast Toy's style Ram Air.
Old Sep 12, 2003 | 06:44 PM
JoSeY's Avatar
I'm getting the 24K supercooler...I appreciate all the input....
One last question...cheapest place to get one? and how do you guys run the lines...I'd lik to use steel braided lines w/an fittings...anyone have a link as to how to do this?
Old Sep 13, 2003 | 04:44 AM
silverTA's Avatar
my trans temp run around 130 to 150 in the city ,,
i had the one in the top
http://www.derale.com/fanmountedoilcoolers.shtml
Old Sep 13, 2003 | 09:18 AM
JoSeY's Avatar
thanks!!
Old Sep 14, 2003 | 09:38 AM
2001-WS6's Avatar
Josey,
You don't have to worry much is you start off with the B&M 24000. Worst case, you can add another one in daisy chain style. I've got a 19000 and a 24000 mounted in series and It lest me hot lap at the track all day long without any problems. The main reason for adding the second one was the fun of construction traffic crawls in the Michigan summers.
Rick
Old Sep 14, 2003 | 01:39 PM
Jorday's Avatar
I installed the B&M 28000 cooler in my car. Worked out pretty nice. This cooler is big enough so it will be a little tight fitting in there installing it, but it can be done. The 24000 will fit easily.
Old Sep 15, 2003 | 10:54 AM
Loudmouth LS1's Avatar
I'm curious, I have a B&M Supercooler 24,000 GVW, if after I put the trans temp gauge in I notice it's not coolin enough, can a fan be added to it, and how hard is it to do that? Also, what should the temp be on a Turbo 400, like at what temp should I worry that it's gettin too hot? Thanks for any help!
