Center arm rest broke?
I always thought the center arm rest was doomed when I saw how it was cantilervered into space. Today I leaned on it to get my coat out from under my butt and the the center arm rest made a bad crack sound. Now it rattles like a piece of crap and the bottom of it is cracked. Anyone have this and is there some fix? The top side looks beautiful but now it taps and rattles when I go over bumps.
its an easy fix, mine was broke when i got it, remove it using the uninstall info on the faq site
it prolly just broke off the front two mounting points inside.. the leather top just pops off..
once you get in there, unscrew it from the mounts and put a generous bead of GOOP adhesive under the bracket. then screw it back down and let it cure with something heavy on it.
then snap the top back on it and reinstall... voila!
the goop holds to both materials very well and is not brittle.. its ''amazing'' hehe.
Yeah - weird. On the bottom a C shaped area about 2" is broken but it is only very thin. It is not hollow inside it has some inner liner. Guess it is coming apart for an inspection. Thanks for the tip on the std CTS version.
just go take it apart all ready, use antizeize on the rear bolts when they are going back in, a real PITA comming out!
http://www.cadillacfaq.com/faq/answe...est/index.html
they all break in the same manner, you will see just get that goop and fix 'er up.
If you're a midget with arms 18" long. Otherwise, no. The CTS armrest is 100000000 X better than the V version. You get storage, you get a much more comfortable armrest because you don't have to lean down when using it. The second you install one, you'll know. And you'll wonder how you lived without it. It's all-day long comfortable...
