Hey new guy here got a ?
I own a 2004 CTS-V and the stability system constantly engages.
Is there any other way to turn this off for good.
I know i can hold the tc button for 5 seconds but you have to do that every time you start the car.
Please help me out.
Thanks
Maxx
Please help me out.
Thanks
Maxx
If its coming on all the time then there is an issue....goto dealer asap.
if its just coming on sometimes when your losing traction or turning, then its doing its job.
To turn it completely off. hold the t/c button for like 15 seconds, or until you see "stability system off" or "disengaged" (dont remember exact wording) pop up on the nav.
There is no way to completely turn it off that I know about.
There has to be a way to turn this off auto maybe a timed relay with matching signal after the car has started or an module for sale some where i would l think anyway.
Well it does come on alot even in cruise on the highway but both the gm dealers in town say they cant find anything with it.
I would say that if your VSES system is engaging while normal driving then you have a problem. ( ABS SYSTEM)
Double check your tire pressures daily while starting your commute!
If thats not the case, never turn off your Stability system because the crash data report would be damming in the incident you crashed and harmed someone.
Mine does the same thing. My understanding is it is due to different size tires frt and rear or different size wheels. The rear tire is not rotating at the same speed as the frt. If you have stock wheels and stock same size tires, then I have no idea. I hate having to turn mine off everytime also.
The vehicle stability enhancement system (VSES) is activated by the electronic brake control module (EBCM) calculating the desired yaw rate and comparing it to the actual yaw rate input. The desired yaw rate is calculated from measured steering wheel position, vehicle speed, and lateral acceleration. The difference between the desired yaw rate and actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM will attempt to correct the vehicle yaw motion by applying differential braking to the left or right front wheel.
The system can only be diagnosed with a scanner and a flow chart.
I had to drive 60 miles to find a small town dealer that would believe me. They replaced the sensor and voila fixed my issue that had been baffling the other dealer on 3 visits and a total of 100 miles put on my car...
Jay
PEOPLE YOUR STABILRAK SHOULD NOT BEING ENGAGING WHILE CRUISING ON THE FREEWAY!!!!!!
if it is doing so, take it to the dealer, and do not take "no" for an answer. Tell them you dont feel safe (and honestly i wouldnt feel safe)
