Stability System Questions
Can someone explain to me why my stability system engages during straigline accelleration. I'll line up to do a 3rd gear pull and roll into the throttle but once I'm at WOT near 5k rpms the car feels really light and sorta wiggles, then I get the warning on the screen letting me know the Stability System has kicked in. I usually put it in Comp. Driving mode for the pulls so the TC system doesn't engage. Is there anything I can do to make the stability system less sensitive. Feels like I have complete control of the car until it kicks in then it gets twitchy.
Making about 500 to the rear wheel. Thanks.
1 press of the T/C button will get you the no T/C light on the cluster. 1 more press within 5 seconds or so will get you into comp mode. From either condition you can press and hold the T/C button for around 8-10 seconds and you will get a message on the nav saying stability control has been disabled.
I noticed from a dig, i get better launches with traction off but still leaving the stability control on..
But then agian I have crappy tires right now so maybe i just cant handle both being off.
Anyone leave the stability on ?
Can you maggied guys get a 5th gear chirp when hard shifting? I just started to get 3rd gear spinning for about 1 1/2 to 2 seconds and 4th gear chirps (Im stock)!! Im pumped because that means that Im starting to time my shifting better now since I've had it for a few weeks!!!
I got the stability system to kick in yesterday on a shift into 5th (not fast, but not slow) when I rolled into the throttle pretty hard. Not sure if I'd call it a chirp, but it definitely kicked in.
Edit: I'm on 19" CCWs though so that could be a factor.
