Who's running a SPEC 3 or 3+
Thinking of upgading. How's the chatter, engagement, pedal effort? Is it street friendly? 3+ is suppose to be SPEC's flagship "still streetable" clutch.
What flywheel are you running as well. I'm not sold on the 3 because it must be pretty grabby being a puck style, but I'd like to hear anyones experience.
Thanks to maxspeed for replying to my PM on this question
The only spec 3's I've driven were on an LT1 camaro and a v6 camaro and it chattered badly on both cars. I've HEARD that they dont chatter nearly as bad on the LS1 fbodys...not sure how that relates to the V, but that is my experience with it.
you guys think the ls7 will hold 475rwhp? once i add the nano kit which should be here next week and long tubes next month thats about what ill put putting out. I havent done much research on it. i only spray from 2nd up no launch and no first gear nitrous. only a few track passes a year.
Prob not most guys with maggies said the ls7 didnt last for them..
But if you dnt track it who knows it might last long as hell.
That's what I would have done if I didn't HAVE to go with GM parts (installed LS7 Clutch kit and remote bleeder under warranty with 1 year warranty on parts/labor)
I anxious to hear how yours works out.
Im running a ls7 slave and i got my bleeder from gforce, i have a thread on this page a bit lower asking for it and he helped me out. I got a great deal on my spec 3+ from adam at MAP http://www.maperformance.com/. Tell him will from jersey told you to call ( not sure if that makes a difference).
I used to run a stage 2+ on my last car so thats why i went with spec, but ive heard good things about monster and the other companies on here. even the ls7.
Perfect. What slave are you using and what flywheel? Source for the bleeder? The 3+ at first seems like a lot of clutch, but the more research I'm doing the more I'm finding that the full face friction materials are the key to some decent streetablitiy without the chatter and some ability to slip it. The stage 2 has kevlar which is very durable but I'm not sold on it. Typical stage 3 like Monster and SPEC are puck styles that actually grip more because the pressure plate is concentrated over a smaller area. They' re supposed to have the least friendly engagement but lots of guys with the Monster 3 have not complained to much. So as wierd as it seems I'll be going full face organic (stage 1) or full face carbon metallic (stage 3+). My decision is more for durability and engagement than holding power. The 3+ is SPECS most expensive set up even more than the 4 or 5.
If your decision is based on durability and engagment I think the LS7 kit would be better for you.
Dont get me wrong Im happy with my spec 3+, but I do alot of stop and go traffic and it gets annoying sometimes.
But.... If you plan do track your car and do alot of hard lanuching then the spec will do the trick and has fair drivability
I plan to upgrade my clutch too! I dont like the stocker other than the light feel of the pedal. I dont like how it shutters when you turn the car off because of the twin-disc.
I want something that is going to hold at least 500RWHP (so i wont have to do it twice) but still be street friendly and at the same time, im going to go with a lighter flywheel. Fidenza maybe if they make it for these cars...
Oh ok. Well thats what i want to replace then but i still might as well upgrade the clutch when i pull it apart so im not doing the work twice. Obviously isnt at the very top of my priority list at the moment but will be there soon.
