Bit the bullet and ordered Kooks 1 7/8
Got a sick deal on them and just wanted to see if you guys had any tips for the install. Im at a toss up whether to spend the extra 100 bucks for studs. I will be using a two post lift and have access to any tool imagineable(thanks to gf's father auto repair shop)
Also I have heard from many people to use new GM factory gaskets instead of the Kooks, are most of you doing this or are the Kooks gaskets good?
Also read somewhere that the Kooks connectors dont come with clamps to connect the connectors to the factory exhaust? I ordered catted pipes and will be connecting it to the factory catback in front of the stock resonator.
Thanks guys, looking forward to seeing if long tubes live up to the hype in the LSX world.
BTW decided to do Kooks because Pacesetters coated with custom connectors was 700 shipped, plus id have to have the cats cut and welded in.
GM gaskets here with no complaints. I also have the studs and again, no complaints. The only thing I has a problem with is clearnce on the steering shaft. I heard one guy ground his steering shaft down for clearnce. Personally, I flattened the primary just slightly right there. I'd rather not grind on things that may impact my life lol
I want to hear what it sounds like with the muffler delete, stock resonator and LT's. I am up in the air over LT's. My last 2 cars have been ungodly loud. Plus my 7 month old son will be in the car occasionally.
As already mentioned you may need to flatten a little the primaries that hit the steering shaft. My kooks 1 7/8 would rub on the steering shaft, I could feel it in the steering wheel vibrating. Oh yeah and reuse the stock gaskets.
BTW i gotta run so ill pm about the purchase tonight when i get to work at 1030, sojersey may be able to help if you want it faster.
Sweet deal man. I picked up a used set of some 1 7/8" off here that literally looked brand new. I had them polished ceramic coated inside/out. They are the catted connectors too. I am waiting for some time to install em so post up your results if you get them in and installed soon. I'm anxious to see what they do.
yea me too, looking at juiced group purchase Kooks is back ordered but Ill call the vendor i bought them from to see(i hope not)....they will be on a day or two after i get them. Anxious to here how it sounds with cats, stock resonator, and no mufflers.....if its too loud which i bet it is....ill throw some magnapacks(14416s) on it. Im over loud loud cars.
Yeah I told myself that I'm not gonna let this car be taken too far like I do all the others. I want to keep it for a while lol. Which is exactly why I did a corsa catback and chose to have catted connectors. I bet your car will sound **** but you'll end up throwing the magnaflows on I bet lol
I ended up finding a nice set of gaskets at my local napa. Good material and they had hooks at the corner bolts which made them easy to slide in.
Those that have installed headers know what im talking about.
stock studs are fine here aswell.
