2007 TBSS Throttle Body on V?
Ive heard this will work but wanna see if anyone has done it. I know its a 4 bolt which is why i want it so i can put a FAST on my car. I just want to make sure it will still connect to the harness without modification.
I think the blade itself is where the size comes from.
Anyway, the harness that you're looking for probably doesn't exist. However this is a common (well maybe not common) swap for trucks that have the older 78mm TB/intake. The harness that they require costs $200 bucks because it actually has to convert the signal to make it run this style of TB. So yours would probably be similar.
You can get LS2 TBs for $200. Just have to look for them.
