Wheel question - backspacing
I'm shopping for winter wheels and tires right now, and of course I got side tracked and started looking at my options for some nice summer wheels. I've read lots about the lack of options we have for wheels, and I've read the FAQ's info about our bolt pattern and offset. I haven't read much about backspacing though. Can our cars fit wheels with any backspace (to create a deep dish or 'lip')? Also, is there any room for movement with the offset of 42mm? Could we go 40mm?
i assume by backspacing you mean offset. due to the brakes we have, it's almost impossible to have a lip without going custom.
consider this, my rears have a 3" and fronts have a 2", but that's with a custom setup.
i for one don't know the exact offset numbers because i basically requested as aggressive as possible.
There are plenty of pages that show how all the wheel fitment terms are related. Here's a pretty good one that came up when I searched.
Based on how his question was phrased I don't think he meant either.
Thanks guys. I have studied a number of those diagrams that explain each wheel measurement, but I didn't realize that offset and backspacing were basically one in the same. Guess I should have studied a bit more.
The only reason why I asked about whether we can do a +/- 2mm offest is because I've seen some wheels that looked like they might fit, but offset was a few mm's off.
Ideally I don't mind zero lip on the front wheels, but I would love to have a 2 or 3 inch dish on the rear wheels. Sounds basically impossible unless I want my wheels and tires to stick out that same amount thought. lol No thanks on that one.
It's really too bad GM had to go and give us these 6x115 hubs ... did they just have a surplus sitting around and needed somewhere to use 'em or what?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
other than the full coil-overs, all i changed was the wheels and tires.
you're not going to find many options that can create a "deep dish" look that are universal to our cars considering the 6-lug pattern, and if you're not changing your suspension, well, you may as well put a "Rancho Package" decal under the V emblem because that's exactly what it's going to look like.
good luck.
good luck.
in my case, considering how low i wanted it, i had to roll the fenders. not too many people like to tuck down to the rim so i really didn't mention it.
although that's hardly custom, quite minimal and mostly comes with the territory with an aggressive setup, and that sounds like what he's looking for considering the BIG LIP requirements.
My only suspension plans are eibach or h&r springs (if I can ever get my hands on a pair) for a little bit less fender gap. Then I'd like 19" wheels with a 2 or 3 inch dish in the rear, and a small or no dish in the front. Ideally I'd also like 295 tires out back with 245's up front, but I know that might be an issue without rolling fenders and possibly other work, so I'll settle for 275's out back. I also don't know if I want the added weight of a wider rim, so 295 is pushin' it on an 8.5" wide rim ... will probably stick to a 275.
So tony tone - I'm starting to see where the misunderstanding began. When you said you had a "custom set up", I was inclined to think you meant custom suspension in order to make the wheels work. I'm realizing now that you must have meant your rims themselvse were custom made. Right? Unfortunately, that's far too expensive for me.
Anyway, what are all the measurements on your wheels? What had to be done to achieve the 2 and 3 inch dish that yours have? I read your suspension mods, I mean what was done with the rim itself to give it that dish and still clear your brakes, etc? Any idea what your offset and backspace measurements are?
i personally don't know much other than the standard sizing (20x9 front, 20x10.5 rear). all the offset measurements and such were done by 360 forged. i basically asked to fit as aggressive as possible and they did the rest.
fwiw, i run a 285 in the rear and it sits very flush. some here have ran 295 and succeeded, but i don't think i can do it because of my ride height.
the only thing missing would be the offset. is that what you're looking for? i can try the owner at 360 to see if he has my measurements off hand... but like i said, it's unlikely you'll find a random universal 1 piece wheel with the same dimensions.
Yes, the backspace/offset is all I'm really interesetd in. If I know those, then I'll know that your numbers work, so I'll know that there's a range from what our OEM measurements are, to what yours are, that will work. That's why I'm asking. Sounds like a pain in the neck for you though, so no worries if you'd rather not do the leg work.
