My Twin Turbo build, with pictures!
#61
this setup so far is very professional, as for ur intake maybe you can run a similar setup to what aerocharger did for there g8 http://www.aerocharger.com/kits_pontiac_g8.php
#70
I tried starting the car yesterday but it wouldn't run for more than a half second. I was hoping the car would at least idle, but the different MAP sensor, IAT sensor and deleting the MAF seems to be too much, lol
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'll post a video of the first start up later this week.
#71
With a modified motor all bets are off as every setup is different, but if its going to blow I would imagine a piston letting go first.
#72
Your car makes me drool!! The hardest part im having when selling my LGT to get my CTS-V is that push into your seat feeling I get when my turbo hit(2500rpm or so in my subie)... The V seems to be like all NA cars and want to wait until 4000-5000rpm to really HIT with power.
#73
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#75
long end of it, go look at my dyno thread and you will see that a V will hit peak at 4500 for torque and hp at 5500. at least for N/A mostly stock. heads, cams, intakes, and/or F/I will change that.
the V is CTS-V doesnt stand for V-Tech, where we dont make any power until 5500 rpm. haha.
#76
Chill bro i loved the old set up. I'm all for the new project.
#77
G-Force re-flashed the ECU today to run with the 2bar MAP and new injectors. Just a base tune, but it should get me running. I'll have the ECU in tomorrow.
#78
The refreshed ECU was perfect, started right up on the first try and ran like normal. I took it around the block, everything seems to be working right but I'm keeping it out of boost until i get the car back to G-Force for WOT tuning.
The only issue that came up is the turbos were siphoning oil from the motor when the car is shut off. The car smokes a LOT when you first start it up because the turbos were full of oil and leaking it into the exhaust. I have two check valves with 1psi cracking pressure on order, should be here next week.
Please excuse the cell phone pictures, I left my digital at home.
Engine bay all cleaned up, I need a strut tower bar if anyone wants to sell me one. Lost mine when I sold the maggie, not a huge deal.
![](http://img715.imageshack.us/img715/7172/enginebay0.jpg)
Dusty as hell, but its all back together.
![](http://img560.imageshack.us/img560/2702/dustybutdone.jpg)
I still cant believe my dumb luck mounting the intercooler and the charge pipe, it literally clears by only millimeters, and I eyeballed the whole thing never measured once!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://img560.imageshack.us/img560/8214/intercoolerbehindbumper.jpg)
the money shot
the money shot
![](http://img600.imageshack.us/img600/2171/moneyshot.jpg)
