A/C not working
So when it finally got warm here in Mass, I turned on my a/c and only warm air was coming out. I looked under the hood yesterday and noticed that I am missing a belt. I have no idea where this belt went. Does anyone know what else this belt drives? I feel as though I am having trouble with my power steering also.
My LS2 has two serpentine belts. One specifically for the AC (closest to the motor) 4 rib,and the much longer serpentine belt that runs the P/S, Waterpump, Alt (closest to radiator) 6 rib. You would have major overheating issues if the one for the waterpump is missing. I would guess you lost the A/C belt, but maybe post a pic and someone could let you know if you are unsure.
You may want to check that the crank pulley is fully seated and inline with the other pulleys. They have been known to walk, though I don't know what conditions cause it, or if you have to mess with it before it becomes a problem.
1 Post
I've replaced several belts on different year CTS-V's and changing both belts should take you 10-15 minutes tops (it pays .2 under warranty). Just remove the primary belt, then the A/C belt, then install in the reverse order. I wouldn't recommend taking any advice from the person who told you to remove the radiator.
1 Post
It won't hurt anything not being spun because it just free spins whenever the clutch isn't engaged. Honestly, I would try to put an A/C belt on it to make sure the compressor doesn't already have a problem that caused the belt to come apart. I've seen some of these compressors have low RPM sloshing issues that cause the compressor to chatter at idle or slightly above idle. This condition usually causes the tensioner to break or the A/C belt to come apart. However, unless you've been hearing a loud screaching before the A/C stopped working I doubt that's the problem.
1 Post
I use a long pry bar in order to get the belt on then I have a long bar with a socket on the end that I use on the tensioner. Sometimes I go below and install them then come up and finish the rest.
I just brought the car to a small shop they said $50 to install so I said ok. They tried and said hell no they aren't messing with it it's too hard, so I'll just wait until my cam install which should be very soon.
Mine has developed a lovely little trick. Blows red hot air for 20-30 mins, then works perfectly. Recently done: Maggie, in tank fuel pump, headers, 8" harmonic balancer. Car has 5K miles, 2006 LS2. Something must have been disturbed somewhere along the line, just don't know what!
1 Post
