P0430
scanner says catalyst system efficiency below threshold Bank 2
I'm guessing my cat is going out?
This is my second one within 10k miles. Not the same one but my drivers side cat went out and now this one. Thank god for GMPP.
Could my cutouts be making these things go bad? My car only has 37k on it. The cutouts are right after the cat's.
i got this code on my evo after installing a turbo back exhaust with a high flow cat. the fix was to add a spacer to where the o2 sensor threads in. I used this how to,
http://forums.evolutionm.net/evo-how...ouler-how.html
It might work for you. Once I had the spacer in, the code never came back. It keeps the o2 sensor cleaner
