243 heads have sodium filled valves?
Got a set of heads from member on here a while back. Sent them out to get ported and milled but the guy I got them from said there was one or two bent valves and they didnt tell me anything what do you guys think? I also had them on a flow bench so if there was a problem ,it would have been caught? Also I was wondering do all the ctsv's come wih the sodium filled valves?any help is greatly appreciated. Thanks
Ok so found out it was off an 06 Cts-V and by that time they had replaced the ls6 with the ls2 right? so im guessing there standard valves. :/ gunna look into swapping them out. Also if i ran the lighter longer valves (at least intake side) i heard that it is the equivalent of running a 1.8 ratio rocker because they are a little longer is it true? again thanks you guys for the help and opinions are always welcomed.
