Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
LAPD Bleeder: Which One
Old 08-10-2011, 12:56 PM
Onefast V's Avatar
Default LAPD Bleeder: Which One
I just bought a LS9X clutch and am looking to buy the bleeder as well. 2005 CTS-V with the OEM slave, do I need to buy the C5/Z06 bleeder or the C6/Z06 bleeder? thanks!
Old 08-10-2011, 01:17 PM
Onefast V's Avatar
Does this look like the correct one? thanks
Old 08-10-2011, 01:40 PM
lollygagger8's Avatar
That end piece on the left (that goes into the slave) looks kind of long
Here's the one I got from LAPD......
Old 08-10-2011, 03:22 PM
Onefast V's Avatar
is that the C6 or C5 bleeder from LAPD?
Old 08-11-2011, 09:23 AM
C6....but make sure you tell him to add the little adapter piece to be able to adapt it to the slave
Old 08-11-2011, 09:37 AM
Onefast V's Avatar
Tick performance informed me that the C6 bleeder is a direct fit on the slave. I asked about a special adapter and they said it didn't need one.. hopefully this is the case!
Old 08-11-2011, 09:55 AM
Nice....life is good after the addition of the remote line!
Old 08-11-2011, 10:17 AM
jcollege's Avatar
Do you need to drop the tranny to install a speed bleeder?
Old 08-11-2011, 10:59 AM
Onefast V's Avatar
I believe so
Old 08-11-2011, 11:52 AM
Unfortunately yes.
Old 08-11-2011, 12:24 PM
jcollege's Avatar
Damn...well this is on the list for when I need a new clutch
Old 08-11-2011, 01:47 PM
I would HIGHLY recommend adding a remote line when you change out your clutch. It's a no brainer. Unless you like being on your back of course
Old 08-11-2011, 03:29 PM
Onefast V's Avatar
Lolly, you did the clutch yourself correct? How long did it take you? Is it difficult with the car just on jacks??
Old 08-15-2011, 12:30 PM
Ya man.....
http://www.cadillacforums.com/forums...h-install.html
Should only take 4 1/2 hours I would think. Shops usually charge $300 for a clutch install.
Old 08-15-2011, 02:27 PM
VeryWhiteDevil's Avatar
ordered mine form SNL Performance 69.95 shipped
Old 02-17-2012, 11:22 AM
DrSpeed's Avatar
What's the difference between these 2 bleeders? Why does the 2nd one need that extra coller?
http://www.monsterclutches.com/shop/...iv/tcrcbl.html
http://www.thelapd.com/profile.asp?I...CategoryID=161
Old 02-17-2012, 01:37 PM
It looks to me like they both have that small piece in the pics. If they didn't, how would you screw it into the slave?
That said, I would make sure I said something when ordering to make certain they include. Never can be too careful
Old 02-17-2012, 02:00 PM
Cadzilla's Avatar
You cannot clear the bellhousing opening with the tick bleeder, period. You have to bend the hell out of that end to get it to fit.
Yes, the end that screws into the slave is long, it bottoms out and moves around even when it is snug. I personally believe it does not seal well. The pitch of the end does not match the stock bleeder either.
I installed mine from tick, and something was leaking. I took it out and could not find any leaks from the slave, only the bleeder. Either I didn't tighten it enough, I jeopardized the seal at the joint when I bent it, or that end isn't the right one.
I'm actually taking mine to a place today to see if they can salvage the line with a better fitting or just make me a custom one..
If not, I'm going with the lapd like I should have in the first place.
Old 02-17-2012, 03:14 PM
.Houdini.'s Avatar
I thought people just notched the bellhousing a bit for that? Anyway, I have a never installed tick performance bleeder for sale for 45 if anyone wants it. I bought it from a forum member but never installed before I sold my V1 to get the V2. PM ME
BTW, my tick bleeder does not have that 45 degree angle bend...it is straight:
Attached Thumbnails LAPD Bleeder: Which One-imag0170.jpg
Old 02-17-2012, 03:31 PM
jmargo's Avatar
PM sent
Quick Reply: LAPD Bleeder: Which One
