Nitrous Outlet Dedicated Fuel System Installed (PICS)
I installed the kit.
Works great! I connected the relay power to the arming switch so the pump activates when I arm the nitrous system.
I removed installed the higher pressure spring that came with the kit and upon flipping the arming switch, I immediatley have 60psi pressure on the regulator. The pump is in the tank and very quiet, just a low hum. I will probably change the regulator hose connections to pretty it up a bit, but the system works great with no clearance issues.
I routed the lines along the existing OEM Fuel lines. Very Clean.
Overall very happy. Only issue was cutting the hose. I got smart and used tape and a cutoff wheel to cut the hose after some frustration using a hacksaw.
Support from Graham and Chris of Nitrous Outlet was instrumental in helping me install this myself. Great Support Guys and THANK YOU!
Set to nitrous tune tomorrow and will hopefully go to Byron the weekend of the 27th to do some test & tune.
![](http://i183.photobucket.com/albums/x99/cbloveday_bucket/dedicated%20Nitrous%20fuel/DSC_0250.jpg)
![](http://i183.photobucket.com/albums/x99/cbloveday_bucket/dedicated%20Nitrous%20fuel/DSC_0249.jpg)
![](http://i183.photobucket.com/albums/x99/cbloveday_bucket/dedicated%20Nitrous%20fuel/DSC_0248.jpg)
![](http://i183.photobucket.com/albums/x99/cbloveday_bucket/dedicated%20Nitrous%20fuel/DSC_0247.jpg)
Having to ice the nitrous bottles down during the summer blows. I opened my bottle many a time when it was 85+ degrees out and the pressure was over 1300 and you couldnt purge it down the bottle had to be iced.
It was great fall and winter but when i drive my car most(summer) it was an absolute waste. Also, the 5 places they gave me to refill, only one could actually fill it and they wanted to certify the bottle(make me pay) before they would even fill it for the first time. I never even got it refilled and i sold it.
I understand. I thought you were going to reference the way it performed when functioning properly. I had to do the icing as well, but so far it has not bothered me as does what it is intended to do flawlessly.
There is a paintball store right down the street from me and they charge less than $10.00 for a completely empty bottle filling. Usually they charge under $5.00 to top it off, so I am blessed there.
